No power window no rear defroster
  • dannyogden541
  • dannyogden541's Avatar Topic Author
5 years 4 months ago #49450 by dannyogden541
No power window no rear defroster was created by dannyogden541
I have a 2001 Infiniti I30 I I was using a test light to try to find out if there was power going to my sunroof. All my fuses are good relays seem to be okay during that whole ordeal I had ended up losing power to the windows all four of them plus rear defroster neither the master switch on the door nor the switches on each individual door are working all for my windows are stuck down all fuses are perfectly fine under the hood and under the dashboard please help
5 years 4 months ago #49455 by Chad
Replied by Chad on topic No power window no rear defroster
A common factor between the windows and the defogger is ground G200. (Left Kick panel.)
File Attachment:
File Name: DefoggerRe...pair.pdf
File Size:656 KB
File Attachment:
File Name: PowerWindo...pair.pdf
File Size:1,238 KB
  • dannyogden541
5 years 4 months ago #49456 by dannyogden541
Replied by dannyogden541 on topic No power window no rear defroster
I forgot to mention the doors lock and unlock button still working from the master window switch
