Rich
  • Jonyquest
  • Jonyquest's Avatar Topic Author
5 years 4 months ago #49404 by Jonyquest
Rich was created by Jonyquest
2003 f150 4.2. P0175. Rich bank 2. Only bank 2. Truck runs ok. No misfires. Just fuel trims are crazy maxed out on bank 2 only. No vacuum leaks. 02 sensors are working correctly. Fuel pressure is good within spec. Intake was resealed before I got vehicle. Fuel pressure regulator isn’t leaking. Truck to old to do fuel injected flow test with snap on triton scanner. How should I proceed?
5 years 4 months ago #49425 by Tyler
Replied by Tyler on topic Rich
What are your trim numbers, exactly?
Do they change at 2500 RPM in Park, or while cruising?
  • Jonyquest
5 years 4 months ago #49430 by Jonyquest
Replied by Jonyquest on topic Rich
Long term is 25. Short term is around 5-15 then randomly go to 0 or back to 15 or higher. Bounces around. If I give it gas it will smooth out and keep short term steady. Unable to actually drive on the road there is no license plate.
5 years 4 months ago #49437 by Tyler
When you say the long term is 25, you mean -25%, correct? What is the other bank doing at the same time?
Time to create page: 0.260 seconds
