1997 Dodge Dakota no power problem
  • Runningbear
  • Runningbear's Avatar Topic Author
5 years 4 months ago #49239 by Runningbear
1997 Dodge Dakota no power problem was created by Runningbear
Ok I am back again and the misfire problem is on the back burner for now as there is a more serious issue. I have a bigger problem with my truck now, I can start it up after changing around the relays from the ASD and other like relay slots and it will run just fine...for about tow or three start ups and then there is absolutely no power going through the system to start the engine. If I have the key in the ignition with one of the doors open the courtesy/cab light will blink and there will be clicking either until I close the door or the batter dies out completely. NO CHECK ENGINE LIGHT came on. I drove to a destination and did my business and then attempt to leave nothing happens.
5 years 4 months ago - 5 years 4 months ago #49246 by Chad
Replied by Chad on topic 1997 Dodge Dakota no power problem
Runningbear post=49239
Is this repeatable? Is it eating relays? Or, is it that just moving them, temporarily, fixes it?
Last edit: 5 years 4 months ago by Chad.
  • Runningbear
5 years 4 months ago #49322 by Runningbear
Replied by Runningbear on topic 1997 Dodge Dakota no power problem
This repeated it self 1 week apart. One Monday it started just fine then it doesn't want to start up again. The following Monday it happened again but with a shorter driving distance. Apparently the relay swap was a temporary fix, not sure if it's eating up relays.
