1992 K1500 speedometer
  • dustin.moen1
  • dustin.moen1's Avatar Topic Author
5 years 5 months ago #49038 by dustin.moen1
1992 K1500 speedometer was created by dustin.moen1
customer had a new engine installed at another shop. no power, runs rough, speedometer and possibly fuel gauge doesnt work. he doesnt remember the tank being that low, but possibly.
found wires switched up, and set the timing. runs fine.
no speedometer. tested @ DRAC module, wht/grn and ppurple/wht and i have 0 volts still, and rising steady voltage as i drive. VSS is working.
I have good ground and power @ DRAC, loaded with headlight bulb.
My output wire, light blue , to cluster ohms out at 0.25.
what exactly is it supposed to be outputting? voltage? square wave? i swapped cluster i had here with known good unit, i do not have a drac to test with.
