Re:2007 avalanche 5.3 flex fuel
  • Cheryl
  • Cheryl's Avatar Topic Author
5 years 5 months ago #48998 by Cheryl
Replied by Cheryl on topic Re:2007 avalanche 5.3 flex fuel
Already looked it never would go into open loop. Always stayed in open loop fault. Also used functional test to put it in open loop still horrible lack of power.
  • Cheryl
5 years 5 months ago #48999 by Cheryl
Plus after that I unplugged both upstream then wot it still garbage. Then unplugged maf still no power. I’m going to redo the injector balance test cold see if they come close to what Ben said around 23 psi for the drop pressure. Tested fuel quality and pressure. Exhaust back pressure. Next want to check cam crank relationship and map sensor because of the strange reading at idle of 2.5 volts
  • Cheryl
5 years 5 months ago #49000 by Cheryl
Plus o2 sensors are being replaced per customer request for heater codes.
  • Cheryl
5 years 5 months ago #49001 by Cheryl
I got it hot and wot it in park and also power brakes it. 3 psi
  • Cheryl
5 years 5 months ago #49007 by Cheryl
@ Tyler it’s the vin 3 lc9 engine
