Novice Scope User, Can't get a good amperage waveform from fuel injector
  • PatrickC
  • PatrickC's Avatar Topic Author
5 years 5 months ago #48894 by PatrickC
Hi all,
I recently purchased a picoscope 2205A and a Hantek current clam with the intention of diagnosing a problem I have. I have a 99 Chevy Motorhome with a 7.4 with a dead miss on cylinder 6. I'm fairly sure it's a fuel injector, but I wanted to prove it. Unfortunately, the injectors are under the plenum so I had to connect the amp clamp to the control wire at the harness about 10 inches from the injector itself. I was unable to get a good waveform. I got a waveform, but it looked nothing like I would expect.
My question is, when scoping a current waveform on a fuel injector, do you need to be very close to the injector itself? If not, is this just user error/ the nut behind the scope?
Any help would be appreciated.
5 years 5 months ago #48895 by Ben
Post a picture of your waveform and your setup and we can help with how to improve it
5 years 5 months ago #48899 by Matt T
PatrickC wrote: I was unable to get a good waveform. I got a waveform, but it looked nothing like I would expect.
If it's broken it won't look normal. Best to practice on one of the good injectors first. If you've got an attenuator test voltage as well.
5 years 5 months ago - 5 years 5 months ago #48959 by Andy.MacFadyen
With a current clamp it shouldn't matter where it goes on the 12v feed wire check your scope is to work on DC signal
Last edit: 5 years 5 months ago by Andy.MacFadyen.
