1999 chevrolet suburban 2500 5.7L Oil filter blew off
  • popoften
  • popoften's Avatar Topic Author
5 years 5 months ago #48802 by popoften
I don't think I have ever had this happen before. Last Thursday I changed the oil on my 1999 Chevrolet Suburban for the first time since I have owned it. When I went to remove the old oil filter I noticed it was only finger tight. There was a bit of oil leakage, nothing major at all. I spun the old filter off with my hand, inspected it to make sure all gasket material came off with the filter, which it did, and cleaned the mating surface with a clean rag and visually inspected. All looked good. I installed a new Purolator oil filter. I lubricated the gasket with clean oil, put it on to hand-tight then gave it another quarter turn with my oil filter wrench. Put in 5 qts of new 5w30 oil per the owners manual. Checked level, Started engine up, checked for leaks, all was fine. Drove it a few miles, checked again for leaks and oil level on the stick, all was fine. Friday through Sunday I drove the truck about 300 miles, all was fine. Today I was going to drive into town and got about a mile when I noticed my gauge was reading zero oil pressure. Turned around and coasted/drove gently home. As I approached home and down my driveway I could see the trail of oil. I had started with a big blowout spot and continued up my 100 foot driveway to the street, and then continued for most of the block. At first I could not find the oil filter, but then found it 3 blocks down at the side of the road. The gasket was intact, undamaged, and not loose or blown. Any thoughts on what could have caused filter to blow off?
  • popoften
5 years 5 months ago #48822 by popoften
Well anyway I put on another oil filter and refilled with oil, will re-check tightness of filter every day for the next several days just to be sure.
5 years 5 months ago #48833 by Noah
That's a weird one man, good thing you were paying attention.
5 years 5 months ago #48907 by 70monte
Wow, never heard of that happening. I own a 98 Chevy K1500 with this same engine that I bought new and have never had that happen. I only tighten my oil filter hand tight and never use a filter wrench on it.
I can't imagine what would cause that to happen if you tightened it like you said.
