No Injector pulse
- Nelsonpacheco23
5 years 6 months ago #48344
by Nelsonpacheco23
No Injector pulse was created by Nelsonpacheco23
I have a 2020 Mercedes Benz Gla 250 4matic with no injector pulse. All fuses are ok and relay as well, this is driving me crazy, Could it be a bad ECM??
- John Curtis
- Thank you received: 111
5 years 6 months ago - 5 years 6 months ago #48346
by John Curtis
It can. Is the no injector pulse also accompanied by no spark?
And can you communicate with the vehicle with a scan tool?
Replied by John Curtis on topic No Injector pulse
Nelsonpacheco23 wrote: I have a 2020 Mercedes Benz Gla 250 4matic with no injector pulse. All fuses are ok and relay as well, this is driving me crazy, Could it be a bad ECM??
Last edit: 5 years 6 months ago by John Curtis.
The following user(s) said Thank You: Nelsonpacheco23
- Nelsonpacheco23
5 years 6 months ago #48347
by Nelsonpacheco23
Replied by Nelsonpacheco23 on topic No Injector pulse
Yes we got spark and no problem with the scan tool. It Communicates with the ECU with no problem
- Ben
- Thank you received: 215
5 years 6 months ago #48349
by Ben
Replied by Ben on topic Re:No Injector pulse
You should have 12v at injector with key on and cranking. Make sure it doesn't disappear when cranking. I don't have a diagram for this 1 but you have to make sure your computer has all powers and grounds. Do you have an oscilloscope? Cam & Crank signals should be checked and several ignition signals should be checked to make sure there not jumping around trying to figure out where the motor is in crank angle space
- John Curtis
5 years 6 months ago - 5 years 6 months ago #48352
by John Curtis
Here’s diagrams if you need em. If you find that you don’t have 12v on power side then you’ll need to check powers going into the module. Same thing goes for the ground. If you don’t have a scope and want to verify a bad ground you can use test light on B- and the ground wire at the injector. It shouldn’t light. You could also go B+ to ground at the injector and crank it and see if it pulses. If not, then check the grounds.
