Tpms interface plug
  • comanchejr
  • comanchejr's Avatar Topic Author
5 years 6 months ago #48332 by comanchejr
Tpms interface plug was created by comanchejr
Hey guys, I have a 2016 Nissan Sentra, I heard there is a tpms interface plug under the dash to reset the tpms. Does anyone know if this year car has this plug? If so what color and how many wires r coming from it or any ideas? Besides going to the dealership.
5 years 6 months ago #48336 by Ben
Replied by Ben on topic Re:Tpms interface plug
If it is a passive system there should be a button to put it in learn mode. In
Nissan cars there usually lower left of steering column. If active monitor sysyem than it has sensors in the wheels and it would turn light off if tire pressure was within range or if there is a hardware fault it would flash for a minute before illuminating solid. Another note for passive system is if there is an abs speed senor problem tpms will be disabled
5 years 6 months ago - 5 years 5 months ago #48458 by soofelton
Replied by soofelton on topic Re:Tpms interface plug
Ben wrote: If it is a passive system there should be a button to put it in learn mode. In
Nissan cars there usually lower left of steering column. If active monitor sysyem than it has sensors in the wheels and it would turn light off if tire pressure was within range or if there is a hardware fault it would flash for a minute before illuminating solid. Another note for passive system is if there is an abs speed senor problem tpms will be disabled happy wheels
Thank you! This helps.
Last edit: 5 years 5 months ago by soofelton.
Time to create page: 0.362 seconds
