2000 cadillac sts 4.6 northstar
  • Fastrider750
  • Fastrider750's Avatar Topic Author
5 years 6 months ago #48258 by Fastrider750
2000 cadillac sts 4.6 northstar was created by Fastrider750
rough idle,rich running no apparent vac leaks maf replaced been tuned and well maintained by owner no dtcs problem appeared suddenly.data for cts shows 62 f then 64 after 3 mins map data looks good can the coolant sensor be bad even though data looks good?
5 years 6 months ago #48263 by Cheryl
Replied by Cheryl on topic 2000 cadillac sts 4.6 northstar
Maybe fuel pressure regulator leaking.
5 years 6 months ago #48264 by John Curtis
Replied by John Curtis on topic 2000 cadillac sts 4.6 northstar
What are STFT and LTFT? What happens to those values of you raise rpm to 2500?
Also 02 data.
5 years 6 months ago #48267 by Hardtopdr2
Replied by Hardtopdr2 on topic 2000 cadillac sts 4.6 northstar
test the iac see if it moves to adjust idle when running rough. odds are it is sticking or going bad. would also be worth while to clean throttle body
