audio control module
  • surplus238
  • surplus238's Avatar Topic Author
5 years 6 months ago #48173 by surplus238
audio control module was created by surplus238
Has anyone else had a problem with no power to the 3a fuse causing the starter not to run? you will need to check the 20a fuse at the audio control module, if the fuse is ok you need to change the audio control module.
Time to create page: 0.239 seconds
