2012 Buick Lacrosse premium engine power reduced and service stabilitrak system
- Jen
5 years 6 months ago #48078
by Jen
Ok so I have a 2012 Buick Lacrosse premium..I love it but have had so many issues. It has 183,xxx miles on it. I've had timing (chain/belt) replaced and a new battery and something with cam sensors... still having issues.
It will say engine power reduced and service stabilitrak. I've used my BF handheld to read the codes when I have issues. P0089 and P228D came on first. Then a day later P0AC4 and P0A90. I bought this car from an auction not knowing anything about it, not even that it was hybrid... please help, any suggestions? Something with my fuel pump or just sensors? Thank you
5 years 6 months ago - 5 years 6 months ago #48080
Replied by Chad on topic 2012 Buick Lacrosse premium engine power reduced and service stabilitrak system
P0089 and P228D refer to the High Pressure fuel rail.
The High Pressure Fuel Pump has a solenoid (a Violet/Black wire and a Yellow wire), that when not powered, allows %100 of the HP Fuel Pump output to pass through to the High Pressure fuel rail. The ECM controls this solenoid, which controls the Fuel Rail Pressure, with a Pulse Width Modulated signal.
P0089 is saying that there is a problem with the PWM signal from the ECM to the Fuel Pump solenoid. Check to verify that you have a PWM signal at the High Pressure Fuel Pump control solenoid. Loss of power, here, will cause high fuel rail pressure and set P228D
Last edit: 5 years 6 months ago by Chad.
The following user(s) said Thank You: Jen
5 years 6 months ago #48081
P0AC4 and P0A90 refer to the Hybrid Powertrain Control Module. I don't know much about hybrid systems. A google search brought this up:
www.autocodes.com/p0ac4.html
Hopefully, someone else can chime in with more info on these codes.
- Cheryl
- Thank you received: 215
5 years 6 months ago #48083
by Cheryl
Replied by Cheryl on topic 2012 Buick Lacrosse premium engine power reduced and service stabilitrak system
What does desired and actual fuel pressure read on your scanner at idle and under load? For high side and low side fuel pressure
- Jen
5 years 6 months ago #48106
by Jen
Replied by Jen on topic 2012 Buick Lacrosse premium engine power reduced and service stabilitrak system
Awesome thank you so much!
