2000 Nissan Xterra condenser fan not turning on.
- cheryl hartkorn
- Thank you received: 130
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
- cheryl hartkorn
- Thank you received: 1138
Monde wrote: The relay is the same one that turns on the ac compressor. The ac compressor is engaging when the ac is on. The only thing I could see is the G/B wire going into the fan motor is open
It looks like there is one relay for the fan ( e66 cooling fan relay), and one for the a/c compressor clutch (e 30 a/c relay)
Different fuses feeding each relay.
Also, if there was more being powered by either relay that wasn't shown on the diagram, there would usaly be a dotted line coming off the relay to indicate such.
Is the fuse that you said shows ground on each side on either one of those relays?
You could try jumping power to the g/b wire either at the relay or at the fan to see if it comes on. Or if you have a scanner, you may be able to do it in a bidirectional test.
- Ben
- Thank you received: 215
- Ben
- Ben
- Ben
- Ben
- Ben
- Ben
- Ben
An open on the RFRI wire from the ECM to the relay would set a DTC as noted by the diagram legend. Can you check the ECM or HVAC module for related trouble codes? Maybe even activate the fan from a scanner?
- ecwurban
- Thank you received: 25
The fan is controlled by the pressure switch on the receiver dryer when it detects high enough head pressure. Not sure on the spec but expect 240+ PSI. If it doesn't turn on and the system isn't blowing very cold then the most likely cause is a low level of refrigerant. If it's low then it'll never reach a high enough pressure to trip the pressure switch to turn on the fan. 90% of poor cooling performance problems are caused by low refrigerant.
When the pressure switch does detect high enough pressure then it'll close a circuit allowing ground to the control side of the condenser fan relay. That then supplies power to the fan motor. If you want to test the fan manually then unplug the relay and supply power at pin 87. Most relays have a little wiring diagram on them. If you check pin 87 with the relay unplugged you should see the ground going through the motor because it's an open circuit. Applying power there will turn on the fan if everything is good. Otherwise if you want to test the rest of the system then turn the A/C on max cold, blower on full blast, open all the doors, let the system operate for a couple minutes to circulate the refrigerant then put a piece of cardboard in front of the condenser. This will cause the pressures to spike and should allow it to get high enough to trip the pressure switch and turn on the fan even if the system is low on charge.
A quick and dirty health test of an A/C system is to turn the A/C system on max cool, full blower, open all the doors then grab the two lines at the compressor. If everything's working as it should then one should be quite cold and the other should be hot. Ambient air temp will have a huge affect on this. If it's lower than 70F out then the two hoses will be closer in temperature to each other. If it's 90+F then the suction line should be uncomfortably cold and the discharge line should be uncomfortably hot. Again, this is a quick and dirty test. It will not match a set of gauges or pulling out the refrigerant to see what's actually in there.
Also I'd really advise you to stay away from those junk top up cans. A lot of them contain garbage sealants that I've seen take out compressors but they'll also contaminate your refrigerant. Refrigerant is required to be 98% pure R134a. If it's not then it can't be pulled out with a regular A/C machine. Otherwise it would contaminate the machine. And them things are expensive. So it would have to be pulled out into a junk bottle. Not all shops are setup for this and it'll cost extra. Top up cans also make it very hard to put in an accurate amount of refrigerant. Systems are very sensitive to the refrigerant level. Both too much and too little have a very negative effect on cooling. And lastly, top up cans don't do anything about air or moisture in the system. Both air and moisture have a HUGE effect on cooling ability. If you don't evacuate that out then you'll never get back to full cooling performance.
- ecwurban
But ya, do not expect this fan to come on right away. Fixed orifice tube style systems will rely more on fans. This system uses a thermal expansion valve (TXV). If it's not a very hot day and there's not much of a load on the A/C system then the TXV will be able to regulate the system all on its own and won't have to cycle the compressor very much at all.
- ecwurban
Your system uses a thermal expansion valve. Some systems with TXVs can take a few minutes to equalize the pressures. But again, you shouldn't have 0psi on the low side... I would definitely suspect an issue with your gauge. Or maybe even with the schrader valve in the low side port.
Generally speaking it's not good if the compressor is making abnormal noise. It almost always means eventual replacement.
But ya, with something like this you really need an accurate pressure reading. The thing to do would be to get a reading of it under light load. Blower fan on low with all the doors and windows closed. Record those readings then crank the blower to full speed, set to recirculate and open all the doors. That'll put a way bigger load on the A/C system and see if the compressor can keep up.
- ecwurban
- ecwurban
