Problem child
- welj31
P0300 is only code.
Tested all the usual stuff again would post results but copy and paste not working.
- welj31
- Paul P.
- Thank you received: 195
Do you feel misfires, cause your counters don't show any. Do you own a scope?
Never stop Learning.
Do any of the Misfire History Cylinder __ PIDs show counts? They should since the P0300 is stored.
Speaking of, when does the Freeze Frame data say the code set? Idle, WOT, cruise? Cold, hot?
- welj31
- welj31
i am not sure how to get to FF data but here is countTyler wrote: Thanks for the screenshots! Much appreciated.
- welj31
- welj31
- welj31
welj31 wrote: Just swapped coils around again and misfire remains in 8/6.
Sorry, I was misreading Giotto. :blush: So the miss counts are on #6 and #8.
Watch the Current miss counts to see under what conditions they tick up.
EDIT: Never mind. That plug sure looks like a dead misfire.
Are you able to do a relative compression test? Or, do you know what to listen for when doing a clear flood crank?
- welj31
- welj31
- welj31
pic one is at 600 rpm
pic two is at 1000 rpm
pic three is at 1500 rpm
- welj31
basic compression test showed
1=165
2=175
3=170
4=180
5=170
6=180
7=170
8=175
just swapped plug around its good
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
- welj31
- VegasJAK
- welj31
BTW it starts on the 3 rotation
- VegasJAK
Put your thumb over plug hole and crank. Can you tell now if oil or ?
