2020 Mazda 6 UPDATED (FIXED)
  • abe1204
  • abe1204's Avatar Topic Author
5 years 7 months ago #47661 by abe1204
2020 MAZDA 6 2.5ltr was created by abe1204
Hello Everyone here , im here again , just asking what really happen About Mazda 6 2020 which is running overheated and car shut down due to radiator was broken and overheated while running And after that car wont start so, towed to the garage sees whats wrong found out that no water in radiator So we filled with water and trying to start but it wont start have no compression so decided to open the head pulled it down and repaired after that it has a good compression and cranking very well , But why there is no spark , I checked the fuse and relays at engine compartment it all fine, I moved my Digital to ignition coil connector has Ground and 12V with ignition on ,So cam and crank see if there is voltage on the connector of cam having 12v both cam ex and cam in are fine too with Ground . next i checke the crank has 5 v reference with Ground ,,Rpm is not bouncing when cranking i checked the crank signal ignition on using my test light as what i had learned iin scannerdanner My test light connected to negative battery coz it a pull down design try to connect and disconnect my test to the crank signal i heard running inside hydraulic valve timing solenoid but nothing spark on the coil.what i think is the computer shitdown itself , while running before beacuase too much hot received from Engine coolant sensor,, befoer i forgot the costumer put a brandnew crank sensor .., stiil wont start hope you guys give a little info and all your answer much appreciated. thank you And Godbless
  • abe1204
5 years 4 months ago #49618 by abe1204
Replied by abe1204 on topic 2020 Mazda 6 UPDATED (FIXED)
I tried so many way I checked all wires power and ground still cranks but it does not start So I decided to Replaced ECM and now start with no Problem
Time to create page: 0.383 seconds
