2011 QX56 5.6l Multiple missfires
  • Richard1
  • Richard1's Avatar Topic Author
5 years 7 months ago #47654 by Richard1
2011 QX56 5.6l Multiple missfires was created by Richard1
Multiple missfire but mostly on Cylinder #2 by far.
Also a 087 Low fuel pressure, however my scanner shows while test driving the Fuel Rail pressure is mostly higher then PCM request by 50lbs to 100lbs or more
This High pressure fuel pump is around $1000 or so, hate to replace it if its a injector problem which are under the intake ouff.
Coil 2 was switched problem remains on #2
Plug 2 was switched problem remains on #2
Compression tester on order should have it this week,
Miss fire on start and low rpm at High rpm seems to be much better no lack of power.
LTFR both banks under 10 combined
Any suggestion so I dont replace unneeded parts, any help is appreciated, very few qualified mechanics in Panama. Dealer suggest replace the pump sure........
5 years 7 months ago #47664 by Cheryl
Replied by Cheryl on topic 2011 QX56 5.6l Multiple missfires
Does fuel pressure hold with key off? If not you could use borescope in cylinder.
  • Richard1
5 years 7 months ago #47665 by Richard1
Replied by Richard1 on topic 2011 QX56 5.6l Multiple missfires
It does not, in the morning I turn the ignition on and I can hear the pump run for at least 30 sec before it stops. I'm guessing I hear the low pressure one in the tank and not the mecanical high pressure one.
5 years 7 months ago #47666 by Cheryl
So the fuel pressure does not hold? There’s your problem
  • Richard1
5 years 7 months ago #47677 by Richard1
Hi Cheryl
Thank you for your help
What would you look for with the borescope?
5 years 7 months ago #47691 by Tutti57
Replied by Tutti57 on topic Re:2011 QX56 5.6l Multiple missfires
I believe Cheryl is talking about looking in the cylinder for fuel leaking in, if you're finding the pressure bleeding down quickly.
