P0130 DTC for 2003 Audi TT 225
  • Rock2000
  • Rock2000's Avatar Topic Author
5 years 7 months ago #47552 by Rock2000
P0130 DTC for 2003 Audi TT 225 was created by Rock2000
Audi 1.8L Turbo engine, 225hp model. The car had no CEL on but the flex pipe in the front exhaust pipe was broken. I replaced the pipe, but then on the first drive got a CEL with the P0130 code. I figured I bent the wire on the pre-cat O2 sensor too much, so I replaced that with a new one. Still the error came back. I borrowed a friend's OBDII scanner to get a better insight.
It seems to enter CL well, and is OK at idle and mild engine rpm changes. But it seems like when I stab the throttle and snap the throttle shut, it enter OL-Drive during RPM down, and then OL-Fault. I notice the EQ_RAT and O2S readings, which normally look OK, are pegged at about 1.999 and 3.2222 during this period and then the OL-Fault is triggered. I thought these readings indicated an out-of-range value that was triggering the fault, but my understanding now is that during this period the ECU is shutting off the fuel? So these lean readings would be OK?
I also checked the short term fuel trim and it seems to be around -7%, which seems reasonable. I'm out of good ideas and will soon revert to randomly replacing parts, which I hate doing. Is there any insights someone might have on this? Anyway to determine exactly what value the ECU doesn't like?
Thanks
5 years 5 months ago #48406 by Orchid70
Replied by Orchid70 on topic P0130 DTC for 2003 Audi TT 225
Hi
Have you found the answer?
I have T4 caravelle from 2001 with same fault code. Its set when lambda sensor heater voltage gets below 10.5V. Its the ground wire from the ECU.
Before realising that this fault was present when the lad bought the van with the cell illuminated and seller told him to get rid of by lifting the battery terminal, I changed the lambda.
I was about to change the ECU - but its hard to find for this petrol, 2.5i engine.
4 years 3 months ago #56916 by Mariowinax1
Replied by Mariowinax1 on topic P0130 DTC for 2003 Audi TT 225
Hello
Did you solve it?
If yes, how?
