2008 acura tsx cranks but no start intermittently
  • Mikeyjoe
  • Mikeyjoe's Avatar Topic Author
5 years 7 months ago #47399 by Mikeyjoe
I have checked fuel pump, fuel relay, crankshaft sensor, and waiting on camshaft sensors. This car starts intermittently always cranks but every so often wont start has gave me no codes ever. Need help
5 years 7 months ago #47416 by Nelson60
What tools do you have to work with? Hopefully a test light and multimeter
How have you checked to confirm the items you listed are good?
If you get it to act up again, you need to find out what is missing that prevents it from starting. Check for spark first,
  • Mikeyjoe
5 years 7 months ago #47420 by Mikeyjoe
Yes ,but i have checked for spark and there was spark, but i can crank once more and it starts it is so hit and miss when it will start and not start.
5 years 7 months ago #47423 by Noah
Does the green key shaped light on the cluster stay lit up when the car is a crank-no start?
  • Mikeyjoe
5 years 7 months ago #47438 by Mikeyjoe
Yes, all in all it doesnt make since even had a friend put a Snap-On scanner on it and he could see know error codes or anything appear to not work it even acted up while he was scanning
5 years 7 months ago #47452 by Noah
If the green key shaped light is lit up the whole time while cranking and not starting, then the immobilizer does not recognize the key and the car will not start.
Do you have a second key programmed for the car, and if so, does it always start the car?
