Ignition key on 1997 buick century
  • Chevyman
  • Chevyman's Avatar Topic Author
5 years 7 months ago #47141 by Chevyman
Ignition key on 1997 buick century was created by Chevyman
I lost the chip in my ignition key on my 1997 buick century. Dealer said I'd need to buy all 15 keys to find right chip. Is there a way to bypass this system with the key with the chip missing?
5 years 7 months ago - 5 years 7 months ago #47147 by AJeep18
Replied by AJeep18 on topic Ignition key on 1997 buick century
The ebay item id given is invalid, no result has been sentI am not an expert, but what I understood is you can bypass the system with a resistor, but you would need the original key, so that you could measure the resistance and get the correct resistor...
you could probably wire each of these in until you find the one that lets your car start. Probably cheaper and easier than buying and having 15 keys cut
Last edit: 5 years 7 months ago by AJeep18.
5 years 7 months ago #47148 by AJeep18
It won't let me post an eBay link but if you search
DEI 652T GM VATS Key Bypass Resistor Kit Pack of 15 GM Multi Ohm Resistors
you will find what I am talking about
5 years 7 months ago - 5 years 7 months ago #47152 by Chad
Replied by Chad on topic Ignition key on 1997 buick century
Last edit: 5 years 7 months ago by Chad.
  • Chevyman
5 years 7 months ago #47157 by Chevyman
Replied by Chevyman on topic Ignition key on 1997 buick century
So I cut purple and white wire and solder the correct resistor in.
5 years 7 months ago #47158 by Chad
Cut the PPL/WHT wire and the WHT/BLK wire. Solder the resistor between PPL/WHT wire and the WHT/BLK wire.
  • Chevyman
5 years 7 months ago #47361 by Chevyman
I just got around to the buick.am I right I saw two tiny white wires in a black cover they were in coming down the column. Are these the two wires that change I to the purple/white wire and the white/ black striped wires.
