Re:2007 GMC Acadia SLT surging
  • jerry r
  • jerry r's Avatar Topic Author
5 years 8 months ago - 5 years 8 months ago #46807 by jerry r
2007 GMC Acadia SLT surging was created by jerry r
2017 GMC Acadia surging when I accelerate going uphill ,checked o2 sensor data under load wot going up hill ,all o2 sensors are rich except for sensor b2 s1 , checked check ed o2 sensor wiring integrity check pins look good did a wiggle test did not find anything replace the o2 sensor but now it's doing the same thing after a couple of days
Last edit: 5 years 8 months ago by jerry r.
5 years 8 months ago #46809 by Dtnel
Replied by Dtnel on topic Re:2007 GMC Acadia SLT surging
So is the downstream sensor fluctuating if you do a snap throttle as it goes up and back down on the O2 sensors?
What type of sensor did you use? OEM, Aftermarket, etc. Replace just the 1 bad one or a pair?
Any other work done prior to this? Was this a recently acquired used vehicle, owned it a long time or?
What are the fuel trims doing?
Sent from my SM-N986U1 using Tapatalk
  • jerry r
5 years 8 months ago #46810 by jerry r
Replied by jerry r on topic Re:2007 GMC Acadia SLT surging
Downstream is responding I only replaced the upstream bank 2
5 years 8 months ago #46812 by Dtnel
Replied by Dtnel on topic Re:Re:2007 GMC Acadia SLT surging
I'm one of those people that has a hard time explaining thingsvs sharing the information. This is a article I refer to at times when beating my head on a hood of a car.
IF you've got a scope by all means use that and you'll gain quite a bit.
Fuel trim numbers, what are they at in the various ranges?
Watch the part where they talk about running idle at various rpm's.
It's cold out in most of the U.S. now so you could very well have a intake leak depending on situation where a scan tool and propane bottle will give you quick answers in that regard.
I need to read my scannerdanner book again as I'm getting rusty as it's been about 5 yrs or so. Very worth the $$$ when or if you choose to make that choice.
Here's the link.
www.underhoodservice.com/fuel-trim-diagn...-sensor-performance/
  • jerry r
5 years 8 months ago #46826 by jerry r
Problem seem to go away at this moment I guess it's intermittent
Time to create page: 0.362 seconds
