05 mazda 6
  • Raucam
  • Raucam's Avatar Topic Author
5 years 8 months ago #46799 by Raucam
05 mazda 6 was created by Raucam
I just got the car from auction and trying to get it fixed. Car runs but when I turn the steering wheel it completely shuts off . With the keys on engine off I checked for 5v reference at the maf sensor and it's there. I checked fuse inside and under hood they are good what I did notice the car won't turn off if I keep my foot on the gas and turn the steering wheel but rpms do drop rapidly then come up also at idle I snap the gas pedal and the rpms drop before it goes up that symptom is the same when turning the steering wheel only that time it shuts the car down. I have cleaned the maf ,throttle body, and I get 14 v at the batt running.
5 years 8 months ago #46803 by jman26063
Replied by jman26063 on topic 05 mazda 6
I would guess that when turning wheel and rpm drops this is a belt driven pump, is pump pulley binding causing too much load on engine?
5 years 8 months ago #46813 by Dtnel
Replied by Dtnel on topic Re:05 mazda 6
Power steering fluid low? Until you said it stayed running I was thinking maybe it was a wire in steering column issue but being it stayed running by throttling it ruled that out.
As others said plus check your fuel Pressure, fuel Pressure regulator & other associated things where applicable.
Sent from my SM-N986U1 using Tapatalk
5 years 8 months ago #46814 by Cheryl
Replied by Cheryl on topic Re:05 mazda 6
Probably the power steering pressure switch
