2007 Mazda CX-7 Dies under Load
  • Babynana
  • Babynana's Avatar Topic Author
5 years 8 months ago #46557 by Babynana
2007 Mazda CX-7 Dies under Load was created by Babynana
Hello, I have a 2007 Mazda CX-7, 107,000 miles. I've been messing with it for a few months now. I have replaced the Crankshaft Sensor, Camshaft Sensor, Plugs, and took the throttle body off and cleaned it.
It will crank up and idle but when you put it under load, it dies. Putting it in drive dies immediately, in reverser it will take a few seconds... when you turn the wheel the power steering load kills it (I have to put the wheel straight to start it back up).
I did notice that when it is idle, I do not get a reading from the 02 sensor 1. It is always at 0.00 on my scanner. It's a scanner that has an app on my phone.
Any thoughts?
Thank You
5 years 8 months ago - 5 years 8 months ago #46560 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2007 Mazda CX-7 Dies under Load
If you are getting 0 v at idle but the O2 sensor gives a voltage ouput if you can raise the RPM and hold it for a few seconds it suggest a fault in the sensor heater circuit.
I would also check for a blocked cat the quick and dirty (and very loud) way to test for this is unscrew the upstream O2 to give the exaust somewhere to go. Trouble is you have already fired the parts shotgun.
Last edit: 5 years 8 months ago by Andy.MacFadyen.
The following user(s) said Thank You: Babynana
5 years 8 months ago #46561 by Hardtopdr2
Replied by Hardtopdr2 on topic 2007 Mazda CX-7 Dies under Load
With the dying at idle/turning you will need to test power steering pressure switch and circuitry. Also do the key on engine off and key on engine running tests with scanner what codes pop up from those tests?
  • Babynana
5 years 8 months ago #46567 by Babynana
Replied by Babynana on topic 2007 Mazda CX-7 Dies under Load
Thank You. I will try that.
  • Babynana
5 years 8 months ago - 5 years 8 months ago #46568 by Babynana
Hardtopdr2 wrote: With the dying at idle/turning you will need to test power steering pressure switch and circuitry. Also do the key on engine off and key on engine running tests with scanner what codes pop up from those tests?
The only code I ever received was the PO335 for the crankshaft sensor. The TSC light is on. I will see if I can test the pressure switch and circuitry for the power steering but it doesn't seem to matter about which load hits the engine, it dies. Just putting in gear without touching the steering kills it too.
Last edit: 5 years 8 months ago by Babynana.
5 years 8 months ago #46573 by Matt T
Replied by Matt T on topic 2007 Mazda CX-7 Dies under Load
Can you rev up the engine with the gas pedal?
5 years 8 months ago #46580 by Cheryl
Replied by Cheryl on topic 2007 Mazda CX-7 Dies under Load
Does it die instantly when put into drive wheels straight? Almost sounds like the wiring harness is being pulled from the engine movement.. I’d try pulling on the wiring harness around the crank sensor. But you could also monitor 5 volt ref to if you wanted
  • Babynana
5 years 8 months ago #46581 by Babynana
Matt T wrote: Can you rev up the engine with the gas pedal?
Yes. You can let it idle... You can rev it up to however many RPM's you want. It will go up and down and up and down with your gas pedal. It's just when you put any load on it. It will die.
  • Babynana
5 years 8 months ago #46582 by Babynana
Cheryl wrote: Does it die instantly when put into drive wheels straight? Almost sounds like the wiring harness is being pulled from the engine movement.. I’d try pulling on the wiring harness around the crank sensor. But you could also monitor 5 volt ref to if you wanted
When you turn the wheel you can hear a strain then it dies. When you put it in reverse it will run for a second or two and then die.... in Drive it dies immediately. Before I put the new crankshaft sensor on, I'd have to wait til the next day to start it. Now with the new one, it cranks right back up but if I have the wheel turned, it will not. I have to straighten it back up to get it to crank back up then it cranks right back.
  • Babynana
5 years 8 months ago #46587 by Babynana
Andy.MacFadyen wrote: If you are getting 0 v at idle but the O2 sensor gives a voltage ouput if you can raise the RPM and hold it for a few seconds it suggest a fault in the sensor heater circuit.
I took the up stream out... No change in how the car acts. Still died under loads, steering wheel, reverse and drive.
5 years 8 months ago #46589 by Cheryl
Is it stalling like it’s running out of fuel? Or does it just shut off like the ignition is being turned off
  • Babynana
5 years 8 months ago #46605 by Babynana
Cheryl wrote: Is it stalling like it’s running out of fuel? Or does it just shut off like the ignition is being turned off
I think I would say more like the ignition is turning off as it doesn't start to sputter or anything like that. It seems to also idle for about 10 minutes and then it will turn off as well. I can crank it right back up when it does that too. Just now noticed that happens.
5 years 8 months ago #46609 by Cheryl
I’d check see if your losing power to coils or injectors. Power wires will be same color wire on all coils or injectors
  • Babynana
5 years 8 months ago #46612 by Babynana
Cheryl wrote: I’d check see if your losing power to coils or injectors. Power wires will be same color wire on all coils or injectors
Thank You. Have to be out of town for a few days. I'm going to get that done late this week and I'll let you know what I find.
5 years 8 months ago #46614 by Hardtopdr2
The crank sensor will need to be scoped if it pops up and check the power, signal and ground wires as well
5 years 8 months ago #46707 by JJJ DA
Replied by JJJ DA on topic 2007 Mazda CX-7 Dies under Load
What does the MAF sensor reads at idle and driving with load? P0335 is still there after replacing it? Any learning missing in ECU?
5 years 8 months ago #46716 by Hardtopdr2
What engine does it have? The 3.0 v6 or 4 cyl?
  • Babynana
5 years 8 months ago #46741 by Babynana
JJJ DA wrote: What does the MAF sensor reads at idle and driving with load? P0335 is still there after replacing it? Any learning missing in ECU?
The MAF sensor reads like anywhere from .8 up to 1.45. No P0335 anymore.. I'm not sure what missing ECU is....
  • Babynana
5 years 8 months ago #46742 by Babynana
Hardtopdr2 wrote: What engine does it have? The 3.0 v6 or 4 cyl?
2.3 L Turbo
5 years 8 months ago - 5 years 8 months ago #46744 by Wightscope
Replied by Wightscope on topic 2007 Mazda CX-7 Dies under Load
Fuel pressure / flow would be my main suspect. When was the filter last replaced ?
You might have static pressure that can fall off a cliff as soon as flow is needed. Graph the pressure against rpm and see if the FP drops out first
Other thought would be that the drive train is locking up, effectively stalling the engine.
Last edit: 5 years 8 months ago by Wightscope.
Time to create page: 0.370 seconds
