12v to all wires to spider injector
  • Giggy76
  • Giggy76's Avatar Topic Author
5 years 9 months ago #45871 by Giggy76
12v to all wires to spider injector was created by Giggy76
I have a 02 s10 with a 4.3 l I have fule pressure and spark no start I tried checking for paulse but all wires to the spider injector have 12 volts and have good compression I am at a lost please help
  • RJMARRA
  • RJMARRA's Avatar
  • 2018 NAPA/ASE Parts Specialist of the Year
5 years 9 months ago #45873 by RJMARRA
Replied by RJMARRA on topic 12v to all wires to spider injector
this systems fuel injectors are ground side switched so you will only have 12v on feed wires with the injectors firing. so it would be 12v & ground only during the firing event. Are you have a no crank no start condition or a no start condition? or even a start run stall condition?
  • Giggy76
5 years 9 months ago #45880 by Giggy76
Replied by Giggy76 on topic 12v to all wires to spider injector
It will start with starting fluid but dies as soon as its gone when I disconnected the harness I got paulse and reconnected it now I have paulse but still won't start cranks really good but no start has 59 psi key on and 65 psi during crank I am so lost
5 years 9 months ago #45883 by southerntruckn
Replied by southerntruckn on topic 12v to all wires to spider injector
On my '98 Z71 you have to have all the sensors (like MAF) hooked up on the air intake tube for it to start. Is that your problem?
  • RJMARRA
  • RJMARRA's Avatar
5 years 9 months ago #45895 by RJMARRA
you don't have a security light or any thing on do you? Also can you scan for any codes?
