2011 F-250 Repeat wheel bearing failure
- Thank you received: 1138
2 years 10 months ago #63739
Replied by Noah on topic 2011 F-250 Repeat wheel bearing failure
Everything I put parts store wheel bearings on only makes it about a year.
- Gordon273
2 years 10 months ago #63741
by Gordon273
Replied by Gordon273 on topic 2011 F-250 Repeat wheel bearing failure
I put motorcraft on this last set and they made it just as long as precision did, about 4500 miles.
2 years 10 months ago #63759
Yikes! Should live longer than the oil filter
- 00Jake00
- Thank you received: 7
2 years 9 months ago #63968
by 00Jake00
Replied by 00Jake00 on topic 2011 F-250 Repeat wheel bearing failure
Something is definingly wrong, no reason why hub bearings can't run 100k. Heck my personal truck (granted it's 2wd) has almost 270k on it and as far as I know they're factory, pretty sure they're Timkin so maybe they were changed at one time but when I first got the truck with 200k on it it needed balljoints along with other stuff of course. When I removed the bearings and cleaned them up they were practically new. Cleaned and repacked those with some delo and never worried about them. Once a year I give the truck a good "tune up" grease everything, change trans fluid (zf5) and rear diff fluid, check brakes, adjusted parking brakes and of course spin the hubs. Never had to re do a wheel bearing job on anything I've done so far. I suggest a better brand. I know everyone says they switch brands but you replace a cheap part with another cheap part there's a very good chance that the 2 parts are actually made in the same plant by the same company they just get tossed in a different colored box. I've heard Timkin quality has went down but so far from what I've noticed they still seem to be one of the best when it comes to anything to do with a bearing. On the old farm equipment we run at home if we have a bearing issue an it ends being a Timkin 99 out of 100 times it wasn't the bearings fault. If we pull it out and it says CHINA though........ well you get the jiff.
2 years 9 months ago #63969
I just had one of my fleet customers in for ball joints and the right front hub bearing I put in over the summer is all ready making noise.
It was definitely a Master Pro or Precision from O Reilly. Not good...
