MISFIRE ON 2,4,6. I HAVE CHECKED DOUBLE CHECKED TIMING. PATHFINDER V6
  • joseph.h
  • joseph.h's Avatar Topic Author
5 years 9 months ago #45703 by joseph.h
'93 PATHFINDER XE , VG30E 6 CYLINDER MANUAL
STARTS ON ONLY THREE CYLINDERS 1, 3, AND 5. 2, 4, AND 6 MISFIRE. I'VE TRIPLE CHECKED THE TIMING THINKING ITS THE CAMSHAFT. I'M GOING TO BE DIAGNOSING THE POWER AND CONTROL TO THE FUEL INJECTORS. I'M PRETTY MUCH STUMPED. THE WIRING HARNES I REPLACED WITH A JUNKYARD HARNES FROM AN AUTOMATIC. I'M GUESSING MAYBE IT'S THE HARNESS OR A GROUND FOR THE HARNESS.
  • joseph.h
5 years 9 months ago #45704 by joseph.h
I'VE REPLACED VALVES IN THIS CAR AND THE FUEL PUMP IS EL CHEAPO AMAZON DIRECTLY WIRED TO THE BATTERY. THE TIMING I COUNTED THE TEETH EXACTLY 40 BETWEEN THE CAMS AND 43 TO THE CRANK. I'M GONNA CRANK IT AGAIN AND SMELL THE PLUGS TO CONFIRM FUEL ISSUE
5 years 9 months ago #45707 by markc
Have you checked for a plugged cat?
  • joseph.h
5 years 9 months ago #45711 by joseph.h
NO, BUT I DON'T THINK THAT'S THE CAUSE. THE PLUGS ARE BRAND NEW AND THEY ARE COMPLETELY ON 2,4, AND 6.
  • joseph.h
5 years 9 months ago #45712 by joseph.h
PLUGS ARE CLEAN ON THAT SIDE 2, 4, 6. I'M THINKING NO FUEL ON THOSE. WILL CONFIRM TONIGHT
5 years 9 months ago #45716 by markc
Arent cylinders 2,4, and 6 on the same side? but you can check for fuel too thats a variable that can easily be eliminated. normally when i run into fuel issues specifically injectors its normally not one complete side, its one on a certian bank or all of them from tarnish or debris...
  • joseph.h
5 years 9 months ago #45718 by joseph.h
EXACTLY! THEY ARE ALL ON THE SAME SIDE. 2, 4, 6 MISFIRING. I JUST THREW EVERYTHING ON AFTER REPLACING VALVES. I'VE TRIPLE CHECKED TIMING BELT WITH MARKS TO SPEC. I WAS FOR SURE IT'S A CAM MISS-TIMED AND I DUNNO WHAT ELSE CAUSED ONE SIDE TO MISFIRE
5 years 9 months ago - 5 years 9 months ago #45720 by markc
ok i didnt see your second post where you had changed valves sorry lol..
Last edit: 5 years 9 months ago by markc. Reason: error in typing
  • joseph.h
5 years 9 months ago #45743 by joseph.h
DONT SMELL GAS ON #2 PLUG. I CRANKED IT AND IT STARTS ON THE 1,3,5 CYLINDERS. BATTERY NEG TO INJECTOR CONNECTOR LIGHTS THE NOID LIGHT. IS IT POSITIVE TO THE SAME SIDE FOR PULSE? ALSO, I DONT HAVE THE EXHAUST MANIFOLD CONNECTED TO THE EXHAUST PIPE SO THERES PROBABLY ROOM TO RELIEVE ANY EXHAUST RESTRICTION
  • joseph.h
5 years 9 months ago #45744 by joseph.h
  • RJMARRA
  • RJMARRA's Avatar
  • 2018 NAPA/ASE Parts Specialist of the Year
5 years 9 months ago #45746 by RJMARRA
Did you check compression?
  • joseph.h
5 years 9 months ago #45755 by joseph.h
I CAN HEAR AIR COMING OUT IF I CRANK IT. I BELIEVE THERE IS AIR SPARK. RN IM CHASING FUEL AS THE CAUSE. I DON'T SMELL ANY FUEL ON THE PLUG. STILL NEED TO CONFIRM PULSE TO INJECTORS.
  • joseph.h
5 years 9 months ago #45760 by joseph.h
COMPRESSION IS PRESENT. INJECTOR PULS PRESENT
  • RJMARRA
  • RJMARRA's Avatar
5 years 9 months ago #45789 by RJMARRA
If all 3 cylinders that are misfiring are on the same bank, did you confirm that the spark plug wires didn't end up on the wrong cylinder? I would double check since its quick and easy! I've attached a firing order diagram for you
  • joseph.h
5 years 7 months ago #47356 by joseph.h
IVE NOW REPLACED THE INJECTORS 1,2 3,4 WHICH HAD BAD RESISTANCE. NO CHANGE. IF THE EGR IS NOT CONNECTED WOULD THAT CAUSE THE MISFIRE ? I CONNECTED THE EXHAUST AND THE O2 SENSOR PIGTAIL WAS CHEWED UPBY RATS. I RECONNECTED THE WIRES. THERES ONLY 1 O2 SENSER IN THIS VEHICLE NOT 2 SO ITS NOT LIKE THAT WOULD EFFECT ONE BANK LIKE THIS ISSUE. GONNA TRY TO PLUG IN THE KNOCK SENSOR AND CONNECT THE EGR SO ITS NOT LEAKING AIR MAYBE IT WILL START. I DON'T BELIEVE THERE ARE 2 CATS EITHER THAT COULD CAUSE BANK 2 MISFIRE
  • joseph.h
5 years 7 months ago #47449 by joseph.h
IVE NOW GOT THE CAR RUNNING ON ALL CYLINDERS. I STARTED IT WITHOUT COOLANT AND IT STARTED JUST FINE. I FULLY ADVANCED THE TIMING AND IDLES BOUNCING AROUND 2K RPM. AFTER THE FIRST TIME STARTING THE CAR HAVING IN IDLE FOR A MIN I REVVED IT AND IT STARTED POURING OUT SMOKE. I THINK IT IS BURNING COOLANT WOULD IDLING IT FOR LIKE 2 OR 4 MINUTS BLOW A HEAD GASKET THAT FAST? THERES COOLANT LINES ALL OVER THE INTAKE I WONDER IF ONE OF THEM IS DUMPING COOLANT IN TO THE INTAKE. HOPEFULLY THAT'S WHAT IT IS. I ALREADY DELETED SOME OF THE COOLANT HOSES THAT CONNECT TO THE INTAKE. I DONT HAVE THE HARMONIC BALANCER CONNECTED SO THERE'S NO ALTERNATOR. I TRIED TO START IT BUT IT WAS MISFIRING ON BANK 2 AGAIN DUE TO INSUFFICIENT POWER TO THE PUMP (IM TRYING TO WIRE IT TO THE FUSE BOX)
RESOLUTION
BANK 2 MISFIRE CAUSED ORIGINALLY BY EITHER DISSCONNECTED EGR (MANIFOLD LEAK) OR FRAYED WIRING TO THE O2 SENSOR.
CURRENT CONDITION
WHITE SMOKE - BURNT COOLANT
MISFIRES - NEED TO WIRE THE FUEL PUMP, DOES NOT HAVE A RELIABLE CONNECTION
WHAT HAVE WE LEARNED. MISFIRES CAN BE CAUSED BY VACUUM LEAKS AND AIR INTAKE AND O2 EXHAUST SENSOR.
I NEED TO READ THE ACTUAL SCANNER COURSE
5 years 7 months ago #47453 by Matt T
Have you smelled the smoke to confirm it's coolant not fuel?
  • joseph.h
5 years 7 months ago #47517 by joseph.h
THANK YOU FOR THE IMPUT ON THE ISSUE. I RAN IT AND PUT MY HAND ON THE EXHAUST WHICH GOT WET AND THERE WAS WATER ON THE FLOOR. I THINK THE ISSUE IS I CRACKED THE LOWER INTAKE MANIFOLD AND THERES A WATER IN PUT THAT GOES INTO THE LOWER INTAKE FROM THE FIREWALL. IM GUESSING IF I BLOCK OFF THE LINE OR REPLACE LOWER INTAKE ( WHICH ILL DO SATURDAY GO TO THE JUNKYARD) IT WILL RESOLVE THE SMOKE
Time to create page: 0.372 seconds
