2013 Mazda Speed 3 P0171
- Jalvrzjn
- Thank you received: 2
- Hardtopdr2
- Thank you received: 150
- Jalvrzjn
Knowing if the code set at idle or higher rpm can help determine if there is a vacuum leak or a mixture issue.
I would check the LTFT & STFT at idle and up to 2500 rpm in park.
Be aware that relocating the maf, such as with an aftermarket charge pipe, can have a negative effect on its ability to measure air.
If it's possible, you could try reinstalling the previous intake tube, resetting the computer and watching to see if the trims continue to trend excessively positive.
- Jalvrzjn
Depressing the clutch while driving will also usually put it into open loop.
It's a good idea to include loop status while you're watching the trims to make sure the trims are being used.
With some of the Ford and Mazda stuff, you may have to reset keep alive memory after you make a repair to get it to start back at it's base fuel map. You won't always see immediate corrections in fuel trims even if you did fix the problem until after multiple drive cycles if you do not. Disconnecting the negative battery cable and touching it to the positive for a minute or two will reset the keep alive memory if you don't have a scan tool that can do it.
- Jalvrzjn
- Jalvrzjn
Jalvrzjn wrote: Great information. Ill have to include loop status while watching my trims. Update on my booster and pcv checks. I plugged hose coming of the booster and no change. And pcv valve is tough to get to, under manifold. I realized if the pcv valve was stuck open i would have excessive vacuum if i remove the oil cap. Am i correct. Also i removed the filter and put a few fingers in front of the maf and my trims started dropping right away. I dont have access to the original intake and a previous shop changed the maf. The maf housing he had previous to the one that is on now had a honey comb in front of it and the one that is on now doesnt. Any thoughts.
The theory is that without that screen the air swirls around making it difficult to accurately sample the air coming into the engine, where as when air is directed through the screen, the air stream is "smoothed out", allowing for a more accurate sample directed to the MAF.
Edit: I'm not telling you all of that because I think it's going to fix the car! Just sharing my understanding of the theory behind the screen.
- Matt T
- Thank you received: 276
www.vehicleservicepros.com/service-repai...turbocharged-engines
This VE calculator works with boost pressure in the baro field.
atgtraining.com/atg-volumetric-efficiency-calculator/
