no comms to TCM with handheld programmer
- jtplowman
5 years 9 months ago #45588
by jtplowman
no comms to TCM with handheld programmer was created by jtplowman
I have a 2007 Chevy Equinox AWD 3.4L V6. I am having transmission issues and need to reset the TCM to relearn the shift patterns. The issue I have is I cannot talk with the TCM using my Tech2. I can talk with every other node on the CAN but not the TCM. I have checked the CAN voltages they are within spec 2.3V and 2.7V. Resistance tests show no grounds or shorts that I can see 60 ohms on the dot, with TCM removed 120 ohms measured to the end resistor and 121.8 back to the ECM. I replaced the TCM and had it programmed for my VIN and still no communication. I replaced the ECM and programmed it myself no issues there and still no TCM communication. I tried and reprogrammed the TCM and it communicated fine through SPS but then no Tech2 comms. I checked the voltage from the battery at the TCM connection and reading 12.2 volts = battery voltage. The ACC signal from BCM reads a bit low at 11.7 volts but there. I'm really lost on what to do next. Any help? Can I some how wire up a bench CAN loop?
thank you
thank you
- Hardtopdr2
- Thank you received: 150
5 years 9 months ago #45589
by Hardtopdr2
Replied by Hardtopdr2 on topic no comms to TCM with handheld programmer
Check the powers and grounds and get a scope capture of can network signals back probing tcm conectors
- Matt T
- Thank you received: 276
5 years 9 months ago #45590
by Matt T
Replied by Matt T on topic no comms to TCM with handheld programmer
Maybe try a different scan tool to see if it can communicate with the TCM.
Another thought is check the VIN is entered correctly in the Tech 2. If the tool thinks the vehicle is a stick shift it won't be trying to communicate with the TCM.
BTW is this a real Tech 2 or a chinese clone?
- jtplowman
5 years 9 months ago #45595
by jtplowman
Replied by jtplowman on topic no comms to TCM with handheld programmer
It’s a Chinese knock off. But I have HP tuners and it acts like the transmission is a manual. I’ll check out the VIN. Thanks.
- jtplowman
5 years 9 months ago #45596
by jtplowman
I have a scope I’ll send what the wave looks like. It’s not got the sharp edges on the front of the bit signals.
- jtplowman
5 years 9 months ago #45659
by jtplowman
This is my CAN bus on the scope. The top lines are my scopes explanation of what it should look like. The bottom lines are my CAN buss. I get this with the old ECM and it’s the same with the new ECM.
- Hardtopdr2
5 years 9 months ago #45661
by Hardtopdr2
That wave form does not look good. I would say to do a pin drag test on the connectors and inspect pins for corrosion/ fluid intrusion and check /clean ground points for tcm, fuse box and pcm. But with the communication working on sps i would say you china knockoff is the problem. However one way to tell is to unplug on module at a time on that section of the network and see if signal improves and comms work again with tech 2. Other wise find a identical car and test comms with it.
As for the adapt relearn can you clear shift adapts with the sps? If so the relearn procedure is done without a scan tool it has 25 steps and repeating parts of it 5 to ten times.
- Cheryl
- Thank you received: 215
5 years 9 months ago #45669
by Cheryl
Replied by Cheryl on topic no comms to TCM with handheld programmer
Are those the waveforms with the engine running? Or just let on engine off??
- jtplowman
5 years 9 months ago #45700
by jtplowman
thanks for the replay. I have checked the grounds at the body they are clean and have <1 ohm resistance. i will try the scope on another vehicle.
- jtplowman
5 years 9 months ago #45701
by jtplowman
this scope was with just the key on and the engine off. I will try it with the engine running. thank you for the reply
- jtplowman
5 years 9 months ago #45775
by jtplowman
tested the can bus on my 2014 Ram and it looked the same on the scope as my equinox did. so i have an issue with my scope. I just bought it. Its a Hantek 1008c. I'm a little disappointed with it. I really don't see a way to calibrate it. So my Can bus must be fine. I really at lost on why I can't communicate with the TCM. I have checked all of the connections voltages and grounds haven't found anything unusual. Resistance is 121 ohms. End resistors are 60 and 61 ohms.
