2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims
- BLEE
- Thank you received: 9
5 years 9 months ago - 5 years 9 months ago #45492
by BLEE
2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims was created by BLEE
Hello,
I am working on a 2000 Honda Accord 2.3L. The car only misfires at idle & as soon as you touch the gas the misfires go away. The short term fuel trim at idle varies from -10% to -25%. The fuel trims get much better as the engine RPM's increase, but as soon as it goes back to idle, the fuel trims are very negative. I am using the MS906BT & I get a random misfire code & eventually a P0301, P0302, & P0304. The parts cannon was thrown at this car from a local dealership and now it is my turn to take a look. The pre cat O2 sensor was showing it running rich since most of the time the O2 was above 450mv. There is now a new O2 sensor in the car & the cross counts & overall O2 readings are much better. I have ensured the EVAP system, fuel injectors are not bleeding down, fuel pressure regulator is good, cat is less than 1 PSI at 3K RPM's, & air filter is good.
I believe the timing is off. I hooked up my oscilloscope and had 2 channels hooked up. I had one channel on my pressure transducer & another channel on the signal going to the distributor from the ECM. My math calculations show the timing is too advanced by around 6.5 degrees. I took off the timing cover and lined up the timing marks & the timing does not seem to be off; but perhaps the belt is stretched since there is over 3/4" play in the belt & I can slide the timing belt off of the camshaft sprocket if I wanted to.
Any help is greatly appreciated.
Brian
Brian
Last edit: 5 years 9 months ago by BLEE.
- AJeep18
- Thank you received: 34
5 years 9 months ago #45493
by AJeep18
Replied by AJeep18 on topic 2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims
Not sure if it will help or not, but I remember watching this a little while ago.
- BLEE
5 years 9 months ago #45498
by BLEE
Replied by BLEE on topic 2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims
Thank you. I will take a look at the video. My relative compression is good, but I will check it the analog way to ensure.
- Cheryl
- Thank you received: 215
5 years 9 months ago #45504
by Cheryl
Replied by Cheryl on topic 2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims
Does it have an egr valve that is stuck open??
- BLEE
5 years 9 months ago #45514
by BLEE
The EGR valve is good to go.
- Cheryl
5 years 9 months ago #45516
by Cheryl
What’s map sensor read while running?
- Martin723
2 years 7 months ago #64751
by Martin723
Replied by Martin723 on topic 2000 Honda Accord 2.3L Mis-Firing & Negative Fuel Trims
I have 01 V6
Going thru the same
Did you ever find out what was the root of the cause.
On mine I replaced
Fuel injectors
EGR plus cleaned ports
Map
TPS & calibrated
IACV
Spark plugs
Ignition coils
Fuel regulator and damper
Fuel pump
Good compression test
PCV valve
No vacumm leaks
Going thru the same
On mine I replaced
Fuel injectors
Map
TPS & calibrated
IACV
Spark plugs
Ignition coils
Fuel pump
PCV valve
No vacumm leaks
Time to create page: 0.325 seconds
