2010 chev traverse trouble code p2099
  • HiloTom
  • HiloTom's Avatar Topic Author
5 years 10 months ago #45331 by HiloTom
2010 chev traverse trouble code p2099 was created by HiloTom
Installed rebuilt motor because timing chain went and messed up motor installed 6 factory fuel injectors and installed new bank 1 cat that was bad and new o2 sensors on that bank but I’m having po2099 which is bank 2 new mass airflow sensor installed car is running beautiful I’m wondering if the bank 2 cat is bad or the 02 is bad
5 years 10 months ago #45403 by Tyler
Replied by Tyler on topic 2010 chev traverse trouble code p2099
It's very possible you have a bad downstream O2. But before that, it's important to check for exhaust leaks between the upstream and downstream sensors on bank two. Light air pressure in the tailpipe and soapy water is the preferred method. Smoke (or just listening for leaks) may not expose pinholes or small cracks.
I know you said it runs great, but I'd still say check your fuel trims anyway.
If you find no leaks and the fuel trims look good, I'd say go for a downstream O2.
