Oil mixed in Coolants
- Loney911
5 years 10 months ago #45284
by Loney911
Oil mixed in Coolants was created by Loney911
Benz A class W169
When coolant indicator blink in dashboard I check the coolant (it mixed with coolant, so I Clean the radiator and replaced new coolant)
Can you guys help me to fix this issue?
I need drawing of coolant system
Do I need to replace Head gasket?
Do I need to replace oil cooler and and it’s gasket ?
Thanks You
Thanks You
- Matronix
- Thank you received: 6
5 years 10 months ago #45285
by Matronix
Replied by Matronix on topic Oil mixed in Coolants
few tests:
open bottle cap
step on the gas, hold high rpm short while, let go
check or bubbles come up in your expansion bottle, or even boiling over
if so.. gasket
other (prefered) test: use gas analyser to check for too high levels of HC (Hydro Carbons) in your expansion bottle (sniff the top of the bottle just after opening the cap). HC can only come from leaking head gasket (or maybe egr cooler but that's not possible on an A170)
open bottle cap
if so.. gasket
The following user(s) said Thank You: Loney911
- Hardtopdr2
- Thank you received: 150
5 years 10 months ago - 5 years 10 months ago #45306
by Hardtopdr2
Replied by Hardtopdr2 on topic Oil mixed in Coolants
you might have a oil cooler leaking in the radiator if it is internal to your radiator. check your oil while draining oil pan for coolant. if none "it most likely will" you may just need to replace the radiator. also check level of your trans fluid as this is another posibility.
Last edit: 5 years 10 months ago by Hardtopdr2.
- Loney911
5 years 10 months ago #45310
by Loney911
Replied by Loney911 on topic Oil mixed in Coolants
Does any one can share me a cooling system diagram of this Benz W169
Class A 170
Thank you
Class A 170
Thank you
5 years 10 months ago #45311
Replied by Andy.MacFadyen on topic Oil mixed in Coolants
Not done one on Mercedes but more generally on other Germany manufacturers and Land-Rover rectangular block style light alloy oil coolers are prone to oil to coolant leaks. Only two tests you can really do if you take the cooler off you could jury rig an air pressure test. T
The other test you could do is for a cylinder head gasket a chemical test for exhaust gas in the cooling water but this will not always reveal a cylinder head gasket.
