What are the g/s at idle for Versa 2018
  • Jayjay100396
  • Jayjay100396's Avatar Topic Author
5 years 10 months ago #45068 by Jayjay100396
What are the g/s at idle for Versa 2018 was created by Jayjay100396
Im work on 2018 N Versa with code PO101 I’m not sure what the maf. g/s should be at idle , my (snap on Modis edge) info Specifies 4-7 g/s at idle I have 1.8 g/s. @ idle and 5.7 g/s @ 2.500 rpm so my maf is bad y/n
5 years 10 months ago #45075 by Matt T
Replied by Matt T on topic What are the g/s at idle for Versa 2018
1.8g/s sounds about right for a 1.6l at idle. Have you looked at freeze frame to see what load and rpm the code set at?
5 years 10 months ago - 5 years 10 months ago #45082 by Tutti57
Replied by Tutti57 on topic Re:What are the g/s at idle for Versa 2018
Like Matt said, that number is good and snap on is way off there, and P0101 is not usually the sensor and is most commonly the air box not sealed good, vacuum leak, exhaust leak in the front, dirty throttle body
Also know that there might be a bulletin for these that requires a software update to the ECM, depending on ECM part number. That's the first thing that needs to be checked I guess.
I've found that Nissans follow that general rule where the g/s is about the same as engine displacement with loads off, warmed up, at idle.
Nissan Tech
Last edit: 5 years 10 months ago by Tutti57.
Time to create page: 0.354 seconds
