Dodge Nitro diesel
  • mashili
  • mashili's Avatar Topic Author
5 years 10 months ago #44923 by mashili
Dodge Nitro diesel was created by mashili
I have ground going to the injectors but there is no 5V ref and when I scan it it giving a fault code P0698. I managed to find the short. It was the three wires going to the CKP which were tightened together with the starter motor but I still have no 5V going to the injectors
  • mashili
5 years 10 months ago #45425 by mashili
Replied by mashili on topic Dodge Nitro diesel
mashili wrote: I have ground going to the injectors but there is no 5V ref and when I scan it it giving a fault code P0698. I managed to find the short. It was the three wires going to the CKP which were tightened together with the starter motor but I still have no 5V going to the injectors
5 years 10 months ago #45426 by Hardtopdr2
Replied by Hardtopdr2 on topic Dodge Nitro diesel
Did you check for 5 volts at pcm?
  • mashili
5 years 10 months ago #45483 by mashili
Yes I did.
5 years 10 months ago #45491 by Hardtopdr2
Injectors should have 12 volts going to them have you checked the fuses
  • mashili
5 years 10 months ago #45510 by mashili
Morning! I checked the fuses the are all fine. Is there any fuse box inside because I can't find one
5 years 10 months ago #45511 by Hardtopdr2
What year and size engine do you have?
  • mashili
5 years 10 months ago #45512 by mashili
It's a 2008 2.8 litre diesel
5 years 10 months ago #45515 by Hardtopdr2
According to the not so helpfull owners manual i looked up it only has the under hood fuse box. (I personally dont believe this as there should be one for interior items and options. Have you looked up under dash , under drivers/passenger seat, under back seat?
The down side i am seeing is the tipm. These are notorious for relay issues for the permanently mounted (soldered on) relays having issues / failing. (This would cause no power to injectors via the auto shutdown relay or a related circuit issue)
www.eautorepair.net . this will have your info needed for diagrams and any possible fuse box locations for your vehicle. As well as recalls, tsb's, and maintenance info for any trouble codes you may have as well as wiring diagrams.
  • mashili
5 years 10 months ago #45518 by mashili
Morning! Thanks for the information will check
  • mashili
5 years 10 months ago #45526 by mashili
I have removed all the seats but no fuse box in the interior
5 years 10 months ago - 5 years 10 months ago #45537 by Hardtopdr2
Ok let me look some stuff up for it. I did find maint info for a 07 nitro diesel. I will post the link to it in a little bit.
Last edit: 5 years 10 months ago by Hardtopdr2.
  • mashili
5 years 10 months ago #45539 by mashili
Thank you! I think even something for 07 can assist
5 years 10 months ago - 5 years 10 months ago #45540 by Hardtopdr2
No eBay APP ID and/or Cert ID defined in Kunena configuration
here's a link to the ebay page for the manual on cd just make sure to ask seller if it includes the 2.8 liter diesel in the cd otherwise the 2007 should have it. the other source I found was a sketchy website that when i revisited it made me believe it was a fake site to scam cc numbers.
hope this helps
5 years 10 months ago #45543 by Matt T
Replied by Matt T on topic Dodge Nitro diesel
If the injectors are two wire I wouldn't expect to see 5V on them.
www.autonerdz.com/yabbfiles/Attachments/CRD.pdf
I haven't been able to find a wiring diagram for the diesel Nitro or Jeep KK. The '07 gas shows a 5V supply to APP1, CKP and TPS on a brown/orange wire. Do you have 5V on the CKP now?
  • mashili
5 years 10 months ago #45544 by mashili
I have 4.9V on brown and blue /yellow CKP. The injectors are two wire
5 years 10 months ago #45545 by Matt T
mashili wrote: I have 4.9V on brown and blue /yellow CKP. The injectors are two wire
If that's unplugged it'll likely be Vref and a pull down signal wire.
Is P0698 still setting? And what other symptoms do you have?
The following user(s) said Thank You: mashili
5 years 10 months ago #45546 by ivoalaska
Replied by ivoalaska on topic Dodge Nitro diesel
Autodata have Chrysler Grand Voyager diagram for 2.8 diesel, its the same engine.
  • mashili
5 years 10 months ago #45549 by mashili
It is not!
  • mashili
5 years 10 months ago #45552 by mashili
I have found it bad it's not its not giving me a detailed report on injectors. The one I have is a 3.40 version
Time to create page: 0.451 seconds
