Re:Wiring diagram does no match...
Tutti57
Offline
Platinum Member
Thank you received: 254
5 years 10 months ago #44872
by Tutti57
This is what mitchell is showing. Is it the same as alldata? I can pull up the one from Assist tomorrow if this is already what you have.
Nissan Tech
Thank you received: 276
5 years 10 months ago - 5 years 10 months ago #44875
by Matt T
Attached are the factory diagrams. If the colors don't match you can probably figure it out from the F33 connector pin-out.
Edit to add the P2135 info in case you need it.
Last edit: 5 years 10 months ago by Matt T .
5 years 10 months ago #44880
by Matt T
If two of the wires are heavier they'll probably be the motor ones.
