P0171 DTC on a 02 Corolla [FIXED]
- Simmer71
LTFT stays at 45 at idle then drops to around 37 at a steady 2k RPM, then goes right back to 45 quickly at idle. STFT bounces from -3.8 to 4 and stays about the same at idle and around 2k RPM.
Under load LTFT drops from 45 to about 27 at a very light throttle then if i give more throttle it goes back up to 43 or 45. STFT bounces all over.
The upstream O2 does switch from 0.0 to 0.8 at idle and will hit all zeros with a throttle snap.
I am pretty stumped with this. I have had a few techs tell me the engine is just worn out and this is why is has that code. I did have a compression test done. 1,3 and 4 were around 155 and number 2 was around 100. So any insight to this would be very helpful.
Normal specification is lowest cylinder should be no more than 10% or 1 bar (14 to 15 psi) below the highest. A 50 psi difference is huge especially as the other cylinders although OK for high miler are already on the low side.
I would do either a wet compresion test or a cylinder leakdown test to determine if it is a valve or piston sealing problem, a valve problem might be worth fixing but piston problem is more involved.
- SniperDan
- Thank you received: 28
~W. Edwards Deming
- SniperDan
~W. Edwards Deming
- Dylan
- Belgium, Europe
- Thank you received: 327
Andy.MacFadyen wrote: The engine is worn out I checked the compressions on a Toyota MR2 last year the compression pressures were about 210psi on 3 cylinders 195psi on the remaining cylinder.
Agree with Andy! Difference in compression is too high. Leakdown test if you can...
What engine is this? Just curious.
SniperDan wrote: It may be a good idea to take a fuel sample and test it for excessive ethanol content. E85 in a non-flex vehicle will cause this condition, and can be a real head scratcher.
Good idea here.
Andy is right on about the mechanical side, too. 100 PSI is barely enough to support any kind of combustion.
- Simmer71
From everything I have read or talked to a few techs about, it is possible it could be the opposite. Low compression would cause a rich running engine.
The engine is the 1.8 1ZZ motor that has the metal intake manifold that uses the metal intake gasket.
I will look into the leakdown test. It may just turn out this low compression could be the issue. I am just not exactly sold that the one cyclinder is causing the issue.
Just for fun earlier, I rechecked the LTFT and this time it was at 44.5 at idle with no load and revving it up to 1500 to 2500 RPM it dropped to 23.4 to 25.5. Let off the pedal and instantly went back to 44.5 and just stays there.
- Simmer71
- Simmer71
- Simmer71
