07 chevy classic 4.8 2wd. "Nightmare"
  • Last chance automotive
  • Last chance automotive's Avatar Topic Author
5 years 11 months ago #44714 by Last chance automotive
07 chevy classic 4.8 2wd. "Nightmare" was created by Last chance automotive
I have been working on this truck for awhile now. It was brought to me after numerous shops attempted to fix it. All they did was butcher it. It was hit by lightning. So when I got it there was a stack of modules in the seat, truck dismantled, wires looked like spaghetti. Long story short finally replaced BCM, ECM, TAC Modules,etc. Fuel pump, injectors, coils. That's a lil history. My question is I can run injector balance test. Truck will crank and run for about 10 seconds, then dies. Then it's a crank no start. But its almost like it wants run?
5 years 11 months ago #44716 by Tyler
Replied by Tyler on topic 07 chevy classic 4.8 2wd. "Nightmare"
The injector balance test should be a bi-directional test in the PCM. Where you find the function exactly will depend on the scanner you're using. If you've never done one before, you just install a pressure gauge on the rail and hit the magic buttons on the scanner. ;)
Speaking of a pressure gauge, have you observed fuel pressure during the start-stall-no start? Any fault codes?
5 years 11 months ago #44717 by Last chance automotive
Replied by Last chance automotive on topic 07 chevy classic 4.8 2wd. "Nightmare"
Sorry I didn't clarify. I was using Snap On Solous Ultra. I had the fuel gauge hooked up as well. The fuel pressure was within specs , based on All data. It never dropped below 60 psi while cranking. It also stayed within specs when it did run for the 10 seconds after Injector balance test.
5 years 11 months ago #44718 by Last chance automotive
It did throw MAF code and oil pressure code. I tried unplugging the MAF with no Avail
5 years 11 months ago #44723 by Cheryl
Replied by Cheryl on topic 07 chevy classic 4.8 2wd. "Nightmare"
Look in engine control module data see if the vehicle is cutting fuel for theft mode. Think it’s called vtd fuel disable. Should stay no not go to yes. Next can you keep it running with alternative fuel to see if that’s why it stalls.
5 years 11 months ago #44733 by Last chance automotive
I was also thinking maybe the Theft mode , was disabling fuel. Upon further inspection I noticed the MAP sensor is bad. I am hoping this will be the issue. I'll have another one tommorow and go from there. Thank you for the response. This has been a huge job fixing all the problems caused by Lightning and other shops.
5 years 11 months ago #44745 by Last chance automotive
MAP sensor. "She's A Runner!!"
5 years 11 months ago #44747 by Tyler
Interesting! What about the MAP sensor made you suspicious?
5 years 10 months ago #44791 by Last chance automotive
I was positive that fuel and firing system was good. Then as I was watching data, while cranking I noticed the MAP sensor data pid did not change while cranking. Can't remember exact numbers but it was around like 10 kpa. Then I checked powers and ground, all was good. Then I checked Resistance of Map sensor key off, it was well below resistance spec via Alldata. Customer was stoked to come and drive the truck home. It was Towed in on the hook, nothing worked on the truck when I received it. Stacks of parts and modules laying in the seat. Several shops fired the parts Cannon at it. The other shops had it over a year and half.
5 years 10 months ago #44792 by Matt T
Replied by Matt T on topic 07 chevy classic 4.8 2wd. "Nightmare"
Last chance automotive wrote: Can't remember exact numbers but it was around like 10 kpa.
That's way too low. Should be around 100 KOEO and 90ish cranking.
5 years 10 months ago #44819 by Last chance automotive
That's right Matt T. When I saw it was at 10 ish I knew I had a problem with MAP sensor. Especially when it didn't rise at all while cranking.
Time to create page: 0.366 seconds
