Re:2006 dodge magnum 2.7 canbus capture
- zar001
5 years 11 months ago #44249
by zar001
2006 dodge magnum 2.7 canbus capture was created by zar001
hey guys new to scopes and well new to the forum. I'm working in a 2006 dodge magnum with the 2.7 have a few u codes directed towards the air bag module. I have the scope hooked up with a break out box the leads are hooked to pin 6 and 14. But I'm not getting a signal I will post pictures any help would be greatly appreciated! Thanks in advance!
- zar001
5 years 11 months ago #44250
by zar001
Replied by zar001 on topic 2006 dodge magnum 2.7 canbus capture
Oh and I have already unhooked the orcm as well.
- Matt T
- Thank you received: 276
5 years 11 months ago #44259
by Matt T
Replied by Matt T on topic 2006 dodge magnum 2.7 canbus capture
Did you have a scan tool communicating with the vehicle when you were scoping the breakout box? If not that could explain no activity?
Also have you pulled those U codes from multiple modules or just the PCM?
- zar001
5 years 11 months ago #44267
by zar001
I just ohmed out 6 and 14 and have 62ohms resistance. And I have u0020 which was in the ocm aswell as u1414 and u1415 codes
- Tutti57
- Thank you received: 254
5 years 11 months ago #44271
by Tutti57
Replied by Tutti57 on topic Re:2006 dodge magnum 2.7 canbus capture
So that reading tells us that the main line is good. Has that occupancy module been replaced? Maybe it was not configured when installed?
What is th customer complaint on this one?
Nissan Technician
Nissan Technician
- zar001
5 years 11 months ago #44274
by zar001
Replied by zar001 on topic Re:2006 dodge magnum 2.7 canbus capture
Air bag light was the main complaint. But the engine was recently replaced. When they replaced engine they said the tipm had issues. So they put a used on in. Well the put a used fcm in aswell not knowing they are two separate units. That's why I'm thinking its got the u1414 and u1415. With that being said any help on being able to configure the fcm?
