Re:Nissan pathfinder crank no start
- Batdrest
I checked the 5v ref in tps it is there and the main relay is activated. Also, check engine is light when you turn on.
Any help???please
- Cheryl
- Thank you received: 215
Knowing that will give you a better idea of where to start looking for the problem.
- Batdrest
Cheryl wrote: Are the cooling fans running on high speed with the key on??
Thank you for your reply
No the fan is not working
- Batdrest
Tyler wrote: Do you have spark out of any of the ignition coils? Injector pulse?
No I didn't get any spark
- Tutti57
- Thank you received: 254
Nissan Technician
- Desmond6004
- Batdrest
Tutti57 wrote: Have you tried another scan tool? Usually the cooling fans turn on with the key on if the ECM is offline. If the can high line is down sometimes you have to disconnect battery to even turn them off. If I get a chance tonight I'll try to look at a diagram.
Nissan Technician
Thank you for your replay
let me ask you Q?. if the security light is always ON when I turn my ignition on is that mean security issue ?
I just want to tell you the car which I check is not USA specification it is r50 type with engine type VG33
- Batdrest
Desmond6004 wrote: Can you scan any other modules?
thank you for your replay
I try pass thru cardaq scan tools but the same.
- Desmond6004
I didn't mean another scan tool, I meant can you scan other modules besides the ECU? Maybe the immobiliser system?
- Batdrest
Yes I can see the TCM and AIRBAG only
