2005 Ford Taurus 3.0 DOHC Wiper Problem
  • popoften
  • popoften's Avatar Topic Author
6 years 3 days ago #44014 by popoften
2005 Ford Taurus 3.0 DOHC Wiper Problem was created by popoften
Hi guys, this is my son's car.
He reports that the wipers stopped working, he discovered 30a wiper fuse blown. He put in another fuse, turned wipers on, and he said fuse immediately blew again.
I told him I would have a quick look during my lunch hour today. I figured I would see if the motor was the problem, so I removed the cowling and unplugged the motor and using a Powerprobe I applied power and ground to the RUN and GROUND pins on the motor and the motor ran. I had a Load Pro lying around (I know, I know, but hear me out) so I back-probed the RUN and GROUND wires on the connector and measured battery voltage on the unloaded circuit, and did find a 1V voltage drop on the positive side of the loaded circuit. That was a bit concerning but I thought I would try to gather more info.
I then reconnected the motor, and put in yet another 30 amp fuse to attempt to see if I could find out what particular setting(s) might cause the fuse to blow. The fuse did not blow for me. Wipers ran fine on regular and fast speeds. I did notice when I turned the switch to OFF that the wipers would not park. They would just stop wherever they were when the switch was turned off. I also noticed that Intermittent mode worked, well, only intermittently. Intermittent would work for a couple strokes, then then wipers would just stop. They would start moving again if I switched to LO or HIGH (non intermittent) mode. I never could get the fuse to blow.
I will continue looking at that car tomorrow.
Any ideas on where I should go from here would be, as always, appreciated!
~ Pop
6 years 3 days ago #44017 by Cheryl
Replied by Cheryl on topic 2005 Ford Taurus 3.0 DOHC Wiper Problem
Maybe the cowel was pinching the wire harness and shorting it.
The following user(s) said Thank You: popoften
  • popoften
5 years 11 months ago #44260 by popoften
Replied by popoften on topic 2005 Ford Taurus 3.0 DOHC Wiper Problem
Maybe. It seems to be working now. Thank you!
