Voltage divider circuit with integrated diode (AC blower resistor)
  • Saverauto
  • Saverauto's Avatar Topic Author
6 years 6 days ago #43975 by Saverauto
Replaced an AC blower motor, old one's commutator was well worn down to it's core.
Also pulled the AC blower resistor. Found a diode integrated into the circuit board.
Tested the diode using multimeters 'diode test mode':
1. ~0.6V in forward direction
2. ~0.9V in reverse direction
Diode allows current flow in reverse direction so assumed it was faulty. Purchased a second hand blower resistor & the diode on that one also allows current to flow in the reverse direction. The diode symbol printed on the circuit board (adjacent to the component) is that of a standard silicone diode.
With old resistor installed, fan speed control is okay.
My questions:
1. What is this diode used for? I'm assuming it's used as a shunt for back emf?
2. Why is this diode allowing current flow in reverse & still allowing proper control of blower speed?
Is it possible that this is a zener diode? In relation to question # 1, I'm assuming then that it's there to regulate voltage?
Thanks.
5 years 11 months ago #44112 by olds88
It sounds like it is in fact a zener diode. Without knowing the circuit design I can't say why they use it, but it is likely that it is used as a voltage regulator.
