2015 ford transit PO720
  • surplus238
  • surplus238's Avatar Topic Author
6 years 1 week ago #43847 by surplus238
2015 ford transit PO720 was created by surplus238
How do I remove this permanent code?
6 years 1 week ago #43881 by Tyler
Replied by Tyler on topic 2015 ford transit PO720
By permanent code, do you mean you found this code in Mode $0A? If so, the only way to clear it is to drive the vehicle several times to show the on board monitor that the issue is no longer present. No amount of scan tool, resetting or battery disconnecting will clear it.
If you mean that the P0720 is showing up as a Current code and won't clear, I'd say check into the Output Speed Sensor circuit. :lol:
  • surplus238
6 years 3 days ago #44009 by surplus238
Replied by surplus238 on topic 2015 ford transit PO720
Thank you for the answer, I have a picture of the wiring harness in my repair manual but I can't find it on the van. I have looked at the wiring diagram and PCM connectors and don't find the pins that serve the tranny. I hopw it is not the sensor as you have to take the tranny apart to change it.
Time to create page: 0.249 seconds
