VW Passat 2004 ABS and ESP issue
  • nilsson
  • nilsson's Avatar Topic Author
6 years 1 month ago #43439 by nilsson
VW Passat 2004 ABS and ESP issue was created by nilsson
Hello.
A Passat 2004 1,8T.
The esp and abs is not working, and the warning light are on.
The codes i found:
65535 Internal Control Module Memory Error
I do not really know what this code is?
01316 - ABS Control Module: No Signal/Communication
Is this code most likely to be problem with wiring or the module it self?
01425 - Yaw Rate Sensor (G202); Signal Wire
Is it most likely to be a sensor or wire problem. The code say wire, but i do not know how to test it.
18256 Please check DTC Memory of Engine Controller
01420 - High Pressure Switch Valve 1 for Electronic Stability Program
This switsh is located inside the abs-modul to preveny to high pressure or?
Is this a commom fault, with some common solutions?
Maybe there are some videos in Scannerdanners large liberary? Im only at first chapter in the diagnostic book yet.
It takes some time to do a chapter with all great videolessons that follow:-)
Thanks and best regards from Sweden.
6 years 1 month ago #43468 by derekoliveira
Replied by derekoliveira on topic VW Passat 2004 ABS and ESP issue
Did you check fuses? best to do before samething else!
6 years 1 month ago #43475 by Ben
Replied by Ben on topic Re:VW Passat 2004 ABS and ESP issue
The Abs control module is a common fault on the b5 and b5.5 passat , with that said don't opt to by a used 1 ,send yours in for rebuild , also it is attached to the abs block and can be removed from the abs block
Sent from my Pixel 3a XL using Tapatalk
