P0449 2005 Grand Prix GT
- thisdj1
At that point a light bulb kind of went off in my head and I realized that I definitely have a wiring issue as the code throws almost immediately. So I started to trace the wire from the harness at the vent solenoid. I noticed as it went through the body plug to the inside of the trunk the wires were broke there as well. So, I fixed those as well, yet again with no luck. I then decided I was just going to cut the wires inside the trunk so I could eventually just wire them straight to the new plug that I had to get for the new vent solenoid. I figured that would reduce the number of connections and limit future issues.
I then used my multi-meter to test the wires for power and discovered that the white wire was reading around 380 MV and the orange wire was receiving no reading at all. In full disclosure, I'm not a mechanic, or any type of super experienced guy with electrical diagnostics. I do however love to learn how to do things as my 5 year old boy is always with me and I want him to learn right along with me. I'm just at a point where I don't know what I should do next. I can't find where there's a fuse for this anywhere, or any type of wiring diagram for that matter.
My thought was, if I could find where the wire originates from, I could start trying to trace it towards the back and see if I can find a fault in it somewhere. I haven't traced the wire from the back any further than the front of the trunk where it disappears again. As far as diagnostic equipment is concerned, I've just got a one way OBD-II reader and a multi-meter. A good friend of mine has a Snap-On diagnostic tool, but he is gone on vacation. So, I"m just looking for some ideas on where to turn to next.
This code doesn't affect the ability to drive the vehicle in any way, it's more of just a challenge to myself at this point. I really appreciate any advice that anyone may have, and I hope I've explained things well enough so you understand where I'm standing at the moment. Thanks in advance!
- Hardtopdr2
- Thank you received: 150
- thisdj1
thisdj1 wrote: I then used my multi-meter to test the wires for power and discovered that the white wire was reading around 380 MV and the orange wire was receiving no reading at all.
Excellent! The WHITE wire is the control wire. The 180mV, that you are seeing on it, is likely a bias voltage. Seeing this indicates that the control wire is good. It is this bias that the computer uses to detect problems. When the circuit is complete/intact. The 180mv will be raised to battery voltage, do to the constant power that is SUPPOSED to come in on the ORANGE wire, and through the solenoid winding. The computer KNOWS there is a problem because it does not see the voltage as battery voltage. Check the Canister Fuse (behind Right side of dash).
- thisdj1
- Matt T
- Thank you received: 276
www.dtcdecode.com/Pontiac/P0449
my.gm.com/content/dam/gmownercenter/gmna...rand_prix_owners.pdf
thisdj1 wrote: You've given me some hope here! However, looking at the fuse block diagram, I don't see a canister fuse for a 2005 Grand Prix.
Make sure you are looking in the correct Fuse Block. There is more than one. Are you looking under/behind the right end of the dash, in the passenger compartment?
- thisdj1
- Hardtopdr2
- thisdj1
Hardtopdr2 wrote: As for your negative lead from dmm touching a bolt or bare metal will work for ground point otherwise if lead is long enough best connection is battery negative.
Trusting a bolt, or frame, as a GOOD ground is risky. Keep in mind that it might NOT be a GOOD ground, especially if your readings come up different than you expected. Negative battery post is ALWAYS the best reference point. A pair of jumper cables can help make it accessible. You only need to hook up the NEGATIVE cable. Now, you have a mobile NEGATIVE battery post (or, the next best thing).
- thisdj1
That is a genius idea! Even for future use. It seems so obvious now, I can't believe I've never realized it before now!
- thisdj1
- thisdj1
thisdj1 wrote: Alright, I owe an apology to the forum... I tried to exhaust all resources before coming here and wasting anyone's time, only to do just that.
No apologies necessary.
Glad you got it fixed!
