Expanded Slide pin rubbers.
- RimmersTechSWE
6 years 1 month ago #43191
by RimmersTechSWE
Expanded Slide pin rubbers. was created by RimmersTechSWE
Ford Mondeo 2nd Generation 2001 Estate
I was refurbishing some rear calipers mildly while waiting for a repait kit. The left side got unstuck fine but the right side is still recalcitrant. Could a swollen slide pin rubber cause the caliper to seize in a manner that prevents the hand brake mechanism (Disc brakes no drum) from operating correctly? The mechanism was free when it was broken up and jammed again when i fully reassembled the caliper. The cable is free so that's not the problem.
- Hardtopdr2
- Thank you received: 150
6 years 1 month ago - 6 years 1 month ago #43193
by Hardtopdr2
Replied by Hardtopdr2 on topic Expanded Slide pin rubbers.
Did you clean out slide pin holes with a bore brush to remove rust build up and old lubricant and relubricate pins with petroleum technical?
Also what color is the brake fluid clear or dark? You might have corrosion on the caliper pistons if its dark and should be fully disassembled cleaned and honed.
Last edit: 6 years 1 month ago by Hardtopdr2.
6 years 1 month ago #43194
Replied by Andy.MacFadyen on topic Expanded Slide pin rubbers.
The self-adjuster mechanism on these frequently gets knackered by incorrect adjustment also if it has the type of guide pin in the picture they are very prone to being damaged ie bent during pad replacement. To pull a badly damaged bent pin out use the pin's thread and a bolt to Mcgyver an extractor.
The handbrake cable must not be over tensioned and condition of the hairpin spring are vital for correct operation of the self-adjuster mechanism
- RimmersTechSWE
6 years 1 month ago #43195
by RimmersTechSWE
Replied by RimmersTechSWE on topic Expanded Slide pin rubbers.
The brake fluid is practically new and theres nothing wrong with the stopping power. But right rear and left front don't properly disengage. I am going to get at bore brush when I get the repair kit in the mail. Both pistons move no problem wehen you retract them. The right rear was really hard to get back in so i suspect it "hydro locks" whenit gets near the bottom.
- RimmersTechSWE
6 years 1 month ago #43196
by RimmersTechSWE
It has automatic ajustment at the lever end and is not over tensioned. The pins are not bent. Ill change the supect one anyway because the threads are bad in it.
It's this type. cdn.autodoc.de/uploads/360_photos/14644612/preview.jpg
- Matt T
- Thank you received: 276
6 years 1 month ago #43202
by Matt T
Replied by Matt T on topic Expanded Slide pin rubbers.
What kind of grease did you use on the pins? If it was anything other than silicone it might have caused those rubber sleeves on the pins to swell up.
- RimmersTechSWE
6 years 1 month ago - 6 years 1 month ago #43203
by RimmersTechSWE
It's a none metalic brake caliper/parts grease but I don't know what has been used previously. Something white. Very similar to this is what i used.
www.mekster.se/bosch-bosch-superfit-649614.html
Last edit: 6 years 1 month ago by RimmersTechSWE. Reason: Clarification
