P0106, P0109, P0135, P0141, P0155, P0161, P0403, P0443, P0645
  • Zaheer
  • Zaheer's Avatar Topic Author
6 years 1 month ago - 6 years 1 month ago #43177 by Zaheer
Currently, i have a Grand Marquis 2001 (GCC specs) with cats removed recently (i have no idea why were those removed) & with P0106, P0109, P0135, P01441, P0155, P0161, P0403, P0443, P0645... With 186411.358 miles... I seek advise & guidance from the professionals with all respect to them. Just to confirm you.. The HO2S11 & HO2S21 are disconnected. (Even if reconnected i still get that codes) Do you want me to check the Power or Grounds ?
Last edit: 6 years 1 month ago by Zaheer. Reason: Added more Info....
6 years 1 month ago #43183 by Hardtopdr2
Put catalytic converters on it first!!!!!
The first two codes relate to the map sensor p0106, po109
The next six codes p0135- p0443 relate to o2 sensors which when cats are installed will possibly clear up along with possibly map codes.
The p0645 is realated to the ac system relay control circuit.
Time to create page: 0.346 seconds
