2011 jeep patriot 2.4L engine Limp mode
  • wes p
  • wes p's Avatar Topic Author
6 years 1 month ago #42959 by wes p
I have jeep patriot goes in Limp mode , had code P0335 (crank sensor) proved out ciruit and replaced sensor and cleared memory and did addaptive relearn , ran good no codes came back sat over nite next morning went to start long crank started check engine lite came on was flashing read codes P0300 and P0335 and went into limp mode, re did addaptive learn ran great scan tool showwed in sycn on cam n crank . could it be PCM loosing memory
  • wes p
6 years 1 month ago #43082 by wes p
Replied by wes p on topic 2011 jeep patriot 2.4L engine Limp mode
Up date the jeep is fixed the crank sensor they sold me wasnt a dealer part even though i exchanged it twice . USE UR SCOPE AT PCM CHECK SIGNAL IS PRESENT THESE BAD SENSORS WERE PULLING SIGNAL TO GROUND
Time to create page: 0.252 seconds
