07 GMC Acadia 3.6l - Engine backfires and stalls after warm up.
- itsmerandy
I am kinda thinking maybe a bad injector?
I appreciate any help.
- Donut
- Thank you received: 11
"Don't ever say 'easy' until the check clears."
- itsmerandy
Thanks
- itsmerandy
This is best I could do. It wouldn't start and run so couldn't record info with Giotto. But had this from friends code reader from couple days ago. Car has new MAF sensor, Fuel pump, timing chains and plugs. And only code that has came up for me is the P0300 random misfire. Sometimes it will act like it wants to start if I hold throttle to floor.
- itsmerandy
- Hardtopdr2
- Thank you received: 150
- itsmerandy
- Hardtopdr2
- itsmerandy
- Hardtopdr2
Can only hope you didnt crack a valve.
- itsmerandy
- Hardtopdr2
Incorrect base timing/ jumped timing belt
Vvt solinoid issue
Knock sensor or knock sensor wire pinched somewhere grounding the circuit.
Its basically something that is used during closed loop. Or timing from whats going on.
Looking at your data, my first instinct is exhaust restriction. It'd match your symptoms, and it's a pretty common problem with this platform. But it's also not the easiest thing to check for. :silly: Since it's not starting right now, have you tried adding some carb cleaner to the intake during cranking?
- itsmerandy
- itsmerandy
Unfortunately I still have some problems with lots of blow by and after having front bank 2 breather line connected to snorkel I am getting lean codes bank 1 and 2. If I disconnect it from snorkel it doesnt pop up with codes. My question is can clogged up cats cause excessive blow by?
On bank 2 I tried unscrewing O2 sensor on exhaust manifold and just let it set in the hole to see if back pressure would blow it out of the hole while running and it didnt.
- Hardtopdr2
Yes it is possible for plugged up cats to stall a motor as the pressure has to go some where. An easy test to do is thread in a fitting to pre cat o2 hole and use a 20 psi gauge with hose. Idle car and do snap throttles record highest reading at snap throttle then rev to 1500 record reading and 2000 rpm. 0-2 psi is normal 3-4 is partial blockage 5 and up you will want to clean or replace cat. If its really blocked you will see high pressures 14-18 psi which would stall engine.
