2017 Jaguar XE 2.0 Turbo - MAF & IAT error code
  • forumoto
  • Christ De KING
6 years 2 months ago - 6 years 2 months ago #42581 by forumoto
A friend of mine had this car at his shop and was trying to repaired it. He has changed pcm, and even changed MAF sensor but still problem exist...
Car won’t throw error code until you hold the accelerator down for some times before you get error codes talking about Maf and iat..
Intake air leakages were checked and all seems fine.
Need some help on this,
The 5 volt reference comes when car start and accelerator pedal depressed... attached file contains images of the fault codes and the wiring diagram..
The car stalled when the sensor is plugged but when it is unplugged car won’t stall...
I have helped him to look for leakage but no leakage, I need help
Christ De Way Maker
Last edit: 6 years 2 months ago by forumoto.
6 years 2 months ago #42588 by Hardtopdr2
Replied by Hardtopdr2 on topic 2017 Jaguar XE 2.0 Turbo - MAF & IAT error code
Back probe maf and iat wires at pcm and write down readings then do the same at maf and iat sensor. After that unplug sensor and check readings again. Then ohm each wire with battery disconnected pcm disconnected and sensor disconnected. they should read zero. If everything checks out then check wire insulation going to pcm for bare spots ahorting to another wire. And check grounds for sensor and pcm. Problem should be in wiring otherwise it may be internal to pcm.
The following user(s) said Thank You: forumoto
6 years 2 months ago #42590 by Matt T
The blue wire looks to be the one that could affect both IAT and MAF, and appears to be a sensor ground. I'd 'scope it at the MAF and see if it's getting driven high.
  • forumoto
  • Christ De KING
6 years 2 months ago #42605 by forumoto
With engine off, key on..
Pin 4 at Sensor side reads 12 volts but when car starts it goes on to battery volts, this test was done without Connecting the harness to the sensor, the pin 2 maintains it Ground/earth ( whether car start or not) , pin 1 also gives 5 volts reference as well as PIN number 3 also gives it close reading to 5 .
I will be posting further more test as prescribed
Christ De Way Maker
  • forumoto
  • Christ De KING
6 years 2 months ago #42609 by forumoto
The blue wire is contain ground which is there when car starts or not, the ground does not disappear, even when connected
Christ De Way Maker
6 years 2 months ago #42615 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2017 Jaguar XE 2.0 Turbo - MAF & IAT error code
Looks like a wiring harness or connector issue to me. Also was the MAF genuine or known good ? ---- lots of fakes around
  • forumoto
  • Christ De KING
6 years 2 months ago - 6 years 2 months ago #42631 by forumoto
Response to-: Andy.MacFadyen
Sensor connector is fine, and if even it is not I had it changed yet stil, bare in mind that the fault does not appear, when you turn the ignition on for more than several minutes, not when you start the car immediately and guarding the idle nature of the car by raising the accelerator a little, so that the car won’t stall, but rather keeping the accelerator at a position for 3-5 minutes or sometimes more
Before the fault codes will show up.
But if you unplug the sensor and you turn the key on, the fault code come up immediately, likewise to other sensors when they re unplug,
So this certified that it is not lose connection , because when sensor was plug and key turn on , no fault codes immediately until car is started and your raise the accelerator in other not to shut it down... for couple of minutes before error codes come up..
Am yet to display other checks requested by other members
Christ De Way Maker
Last edit: 6 years 2 months ago by forumoto. Reason: Response to -: Andy.MacFadyen
6 years 2 months ago #42636 by guafa
Hi everyone,
Taking a review of Paul's book, there was a case which a Map performance code was set because TPS was out of range.
The tricky part of that was no mitchell neither other database but snapon scanner, gave him a clue on how the code was set (tps out of range).
6 years 2 months ago #42640 by Matt T
forumoto wrote: for couple of minutes before error codes come up..
Do all four codes set when this happens?
  • forumoto
  • Christ De KING
6 years 2 months ago #42656 by forumoto
guafa wrote: Hi everyone,
————————-_______
You see if you don’t use the accelerator pedal to hold the gas able some certain height, the engine will stall or die when you start.
Christ De Way Maker
  • forumoto
  • Christ De KING
6 years 2 months ago #42657 by forumoto
Yes please the codes all appear... or sets in... reading the live data of the Maf and iat, you can see that they re not responding well, another car MAF sensor was tried yet still, original sensor was taken to the other, it’s perfect
Christ De Way Maker
6 years 2 months ago #42663 by guafa
In your first post. Do you mean 5volts change with throttle released?
What is your Map reading with Maf unplugged?
Can you post all PID's with and without Maf plugged?
Time to create page: 0.325 seconds
