Fixed 02 RAM 1500 4.7 IT'S BACK
- gilbert
- Thank you received: 15
The ram is back the oil pressure is fine and truck seems to be running fine but the engine light is on. I pulled codes on it and get p0171, p0455, p0202, p0123 and p1281. The truck needs to pass smog in California, here is the freeze frame code and pending code all help is greatly appreciated thank you.
- SniperDan
- Thank you received: 28
~W. Edwards Deming
- gilbert
Hey SniperDan the truck is running good the owner said it ran a little rough in the morning. I will check that out this morning, I also think I should start with the injector thank you. In did not feel a misfire when it got here .
I say you should feel free to skip the P1281 and P0455 for now. It'd be cool to tie the lean code and the injector together, but they're on opposite banks.
I'm with Dan about chasing the injector code first. Does this have a remote start? I see those crappy ScotchLock connectors causing injector codes all the time.
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- SniperDan
~W. Edwards Deming
SniperDan wrote: I thought similarly on tying the P0455 and the P0171, but this being a speed density engine it is doubtful. In fact, i highly doubt that a vaccuum leak is playing a part in any of these fault codes, though it could be contributing to the roughness on cold start. A purge solenoid that was stuck open or any vaccuum on this setup would be expected to cause a high idle, and subsequently a P05 series fault code, and wouldnt have a hige affect on fuel trims. Knowing Chrysler, I'd be willing to bet we have some sort of an oxygen sensor issue contributing to the P0171, though I'll admit this is purely speculation with no founding on applicable data. Speaking of data, think you can get some captures? Particularly fuel trims, loop statuses, and oxygen sensors to see what we are working with.
Oooh, good thinking here, sir! Chryslers are slaves to their O2 sensors, after all.
- gilbert
Hey Tyler I'm happy to say that the oil pressure is good thank God. This truck has no remote start, pending codes are p0133 and p0442. I checked the injector and I have battery voltage when running and pulse on signal wire. I do hear the injector,I also did a cylined drop test and hear no change on cylinder 2 I do have good spark. Cylinder 4 drop test truck almost stalled. I have a External Multiscope but I don't know how to set the settings to get a good wave pattern.
SniperDan I will try to get those shots tomorrow for you thank you all for your help.
- SniperDan
Amperage setup- 20ms sweep, 5 amp scale, peak detect on, invert on depending on amp clamp polarity/position. You can install the clamp on either the feed or control wire, it matters not.
Voltage setup- 20ms sweep, 100v scale, peak detect on, no inversion neccesary, negative lead on the battery negative, positive lead backprobed in the injector control wire.
~W. Edwards Deming
- SniperDan
~W. Edwards Deming
- gilbert
God bless you my brothers and sisters.
SniperDan i took thees shops of the injector hope this helps. I was also looking at long and short trims with o2s and i noticed that bank 1 sensor 1 was not working. From experience i know that the o2s on thees truck can cause a lot of problems I'm going to replace the o2s and see what happens.
- SniperDan
~W. Edwards Deming
- SniperDan
~W. Edwards Deming
- gilbert
So I checked and replaced the 02 sensor and fuel trims are good thank God. As for the po455 the fuel cap was leaking. Brother I did insert the pics but they did not show up then I attached them and same thing.
gilbert wrote: God bless you my brother's and sister's.
Nice! :woohoo: Should I call this one [FIXED] for now?
Looking back, seems like SniperDan suggested a bad O2 sensor on the first page, points to him.
- gilbert
It's been a week and it hasn't been back thank God.Im going to call this a fix. Bad O2's sensors.
Did this also end up passing emissions inspection?
- gilbert
I don''t know if it passed it has not been back though.
Thank you all for your help.
- Thank you received: 1138
No news is good news!gilbert wrote: God bless you my brothers and sisters.
