Ignition Switch or Ignition Cylinder problem.
  • John Curtis
  • John Curtis's Avatar Topic Author
6 years 2 months ago #42246 by John Curtis
2003 Colorado Parasitic drain problem. When I opened the door I heard the dinger immediately. The key works to turn it on and if I turn the key off it will shut off properly however, it feels like there is no detents/stops and you can go a little too far when you turn it off and it will cause a drain. It will also cause the dinger to go off. It feels 100% mechanical so I believe I it is the cylinder that is the problem and not the ignition switch. The ignition switch is functioning correctly electrically. Any insight or ideas as to differentiate between the two?
6 years 2 months ago #42267 by Noah
You could try to remove the lock cylinder and move the contact switch with a screw drive to see if the binding is in the lock cylinder or switch.
