2006 Nissan Micra AK12 1.2L engine, cranking but not starting
  • RobbieNashwin
  • RobbieNashwin's Avatar Topic Author
6 years 2 months ago #42134 by RobbieNashwin
Hello all, I badly need some help, I just worked on the above car where I changed the piston rings, head gasket and other gaskets on the engine following a compression test which improved greatly on the wet compression test. I have assembled the car and now the car will crank up but will not start. Can someone please help?
6 years 2 months ago #42135 by guafa
Are injectors and spark plugs firing?
Those engines have a CKP sensor and toothed wheel in the flywheel. If that sensor is not working all the system doesn't react.
Can you also check timming with scope?
  • RobbieNashwin
6 years 2 months ago #42211 by RobbieNashwin
Hello there i checked the ignition coils n spark plugs by removing them and using a jumper cable to connect spark plug to ground cable and when cranking, i see sparks on the plugs. Did that for all 4 ignition coils amd they are all good. Checked the crankshaft position sensor (3 wires) and the camshaft position sensor (3 wires) for ground and power and they are all good.
I have a second nissan micra and swaped those 2 above mentioned sensors to the other car and they work perfectly coz the other car started up without any problems.
What can i do more now?
6 years 2 months ago #42214 by guafa
So you have spark, which means ckp seems to be ok and synchronizing spark and fuel (i am supposing injectors are firing also).
I would check if engine starts with starting fluid or propane.
I would also check for timing. Do you have scope? One trace on ckp and other on spark plug control wire cylinder 1/4.
